As I said in the off road forum, 2 inch front end leveling spacer and Add A Leaf in the back added to a full 6" suspension lift will fit them.
YES you will need to regear...as I said.
IF they make 4.88 gears for the front end(Which I have seen, but this is still a little unsure), then 4.88s would be a good choice, but if not, 4.56s would do fine.
