video from inside an engine
Old Oct 10, 2007 | 10:02 AM
tomtoc's Avatar
tomtoc
actual video: http://www.liveleak.com/view?i=73e_1192001762
pretty cool stuff
EDIT: graphic and description: and here's a good description of what you're seeing
http://auto.howstuffworks.com/engine1.htm
  1. The piston starts at the top, the intake valve opens, and the piston moves down to let the engine take in a cylinder-full of air and gasoline. This is the intake stroke. Only the tiniest drop of gasoline needs to be mixed into the air for this to work. (Part 1 of the figure)
  2. Then the piston moves back up to compress this fuel/air mixture. Compression makes the explosion more powerful. (Part 2 of the figure)
  3. When the piston reaches the top of its stroke, the spark plug emits a spark to ignite the gasoline. The gasoline charge in the cylinder explodes, driving the piston down. (Part 3 of the figure)
  4. Once the piston hits the bottom of its stroke, the exhaust valve opens and the exhaust leaves the cylinder to go out the tailpipe. (Part 4 of the figure)
Old Oct 10, 2007 | 06:42 PM
godblessmud's Avatar
godblessmud
that was a pretty neat video there. not sure if the explication was nescisary since im pretty sure that most of us understand how an ICE works...
Old Oct 10, 2007 | 06:48 PM
cleeE150's Avatar
cleeE150
amazing what they can do with vidio, cool............
Old Oct 10, 2007 | 07:53 PM
JLDickmon's Avatar
JLDickmon
  1. Then the piston moves back up to compress this fuel/air mixture. Compression makes the explosion more powerful. (Part 2 of the figure)
  2. When the piston reaches the top of its stroke, the spark plug emits a spark to ignite the gasoline. The gasoline charge in the cylinder explodes, driving the piston down. (Part 3 of the figure)
I know you didn't write that, so I can pick on it.
The air/fuel mixture does NOT "explode"
It is a burn rate dependent on quite a few design factors, but the rate of burn is design dependent nonetheless
Old Oct 10, 2007 | 08:33 PM
godblessmud
i beleive "combusts" would be the proper term...
