92 on a 85
Old Oct 10, 2007 | 07:30 AM
80demoace's Avatar
80demoace
92 on a 85
I just got a rusted out 85 ford 1 ton 4x4 and a 92 1/2 ton 4x4 (cab is clean on the 92). My question is will the 92 body go right on the 85 chassis. I know the wiring is different but I can make that work, just wondering what other problems I may run into. I would just run the 1/2 ton but I need a real truck, my average empty weight is around 7000 (tools, supplies). Then I hook up the trailer.
1992 1/2 ton 300-6 5spd. mazda, reg cab long box.
1985 1ton 460, 4spd. reg cab long box
Old Oct 10, 2007 | 03:46 PM
big hoss 29's Avatar
big hoss 29
The body should bolt right on your 85 frame. Ford didn't change frame dimensions from 1980-1996. More than a few members here have done the swap too.
Old Oct 11, 2007 | 02:31 PM
blue beast's Avatar
blue beast
IF it didn't now is the time to make some brackets an make it a body lift while your at it!! I want to put a Mack R model cab on my bronco frame, with the air ride and big hood (maybe a superliner hood!!) It would be different that's for sure!!
