speedometer?
Old Oct 12, 2007 | 12:45 AM
lucky no. 7's Avatar
lucky no. 7
no you didnt confuse this ole hillbilly, i know that tire diameter affects speedometer reading, and as far as the drive gear goes i cant say that i've ever seen a c-6 with a removable gear, all of em i've seen are machined into the output shaft, i figure 1000 revolutions is good to start with, but i was wondering if that applied to our trucks, preciate teh help though, that calculator is something thats a favorite now for sure
Old Oct 12, 2007 | 03:42 PM
classicranger's Avatar
classicranger
Here is a good one to have also
http://www.warwickdragway.com/Calculators.html
Old Oct 12, 2007 | 04:08 PM
blue68f100's Avatar
blue68f100
The C6 output shaft is fixed as stated. The nylon gear on the speedo drive is changeable. The Speedo (dash) is calibrated to either 15/16 rev of the C6 tail shaft to 1 rev of the cable (don't remember the exact #). I found this out when I purchased a digital speedo for my 68. This is a std that all speedo are calibrated too. The digital speedo I purchased can compensate for any tire size. All you have to do is push a button and drive 2 mi, then push the button again.
Old Oct 12, 2007 | 11:42 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
C-6 with short cast iron hsg used on trucks had the drive and driven gear made of steel, last short C-6 ext hsg was aluminum same length as iron hsg it used a car type plug-in speedo w/a nylon gear. Speedo plugged in on the drivers side. Iron truck hsg speedo screws in on the passenger side.
Are we having fun yet?
Old Oct 12, 2007 | 11:46 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The nylon speedometer driven gears are still available from Ford. 15 thru 21 tooth gears are what's available.
Old Oct 13, 2007 | 04:40 AM
Danger_Dave's Avatar
Danger_Dave
a c6 with 4.33's ?
holy smokes !
Old Oct 13, 2007 | 09:53 AM
68FE390's Avatar
68FE390
So what nylon gear do I need with 4.33s and a 30inch tall tires.
Old Oct 13, 2007 | 01:21 PM
classicranger
I come up with 26 tooth gear wich isn't made, biggest i find is 23.
http://www.mustangsunlimited.com/key...gear&x=11&y=21
TheKirbyMan
39
Sep 1, 2019 04:12 PM
ryancawby
16
Mar 20, 2019 01:31 PM
68FordTruckMan
15
Oct 20, 2015 06:07 PM
MIKES 68 F100
Jul 29, 2015 04:51 AM
JacobRM
19
Jun 3, 2014 06:35 PM
