.86 King Pin . . . Reamer?
Old Oct 10, 2007 | 12:31 AM
Ira Brown's Avatar
Ira Brown
Where to buy a King Pin Reamer?
I have my king pins for my 58 F100 and just measured the pin. It measures
.86. Where do I find a king pin reamer? Do I look for a .86 reamer. The bushings measure about .845.
I found this info through a search on a 56.
According to the 56 ford truck shop manual the bushing is 0.861 ID and the spindle is 0.859 OD
The FOMOCO part# for the reamer is: T53T-3110-A
Old Oct 10, 2007 | 11:22 AM
HT32BSX115's Avatar
HT32BSX115
I removed the front axle from my F-600 and took it to a big truck front end shop in Kent, Wa.
They used a Sunnen hone to hone the holes oversize for the new king pin kit. When I got it back I put it together and the front king pins not only fit perfectly buy they moved like ball bearings.
I don't think the whole deal was more than about $175 including the king pin kit.
Cheers,
Rick
Old Oct 10, 2007 | 11:51 AM
packrat56's Avatar
packrat56
Im not sure how they are on a 58, but on my 56 I just removed the spindles and had a machine shop do them for about $20... Not worth buying the tool!
Old Oct 10, 2007 | 02:22 PM
ALBUQ F-1's Avatar
ALBUQ F-1
These reamers show up on eBay all the time; some guys buy them to ream their bushings, then sell them slightly used. You can do the same!
Old May 7, 2008 | 08:46 AM
51ford fan's Avatar
51ford fan
I called my local Napa store yesterday and they quoted me $93.00 to ream the King Pin bushings. Looks like I need to call around somemore, or look for a Reamer myself.
Old May 7, 2008 | 11:51 AM
rbaker6336's Avatar
rbaker6336
at $93 that's about $360 an hour
Old May 7, 2008 | 12:11 PM
packrat56's Avatar
packrat56
Perhaps try to find a machine shop that has been around a long time, even a shop that works on trucks (tractor/trailers) ??
Old May 7, 2008 | 01:22 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Whatever you do, where ever you go, make sure they ream BOTH the top and bottom bushing at the same time, with one long tool. If you ream them separately, they won't necessarily align with each other. Each may have the correct diameter but pointing off in a different direction than the other. This may seem obvious but "common sense is anything but..."
Old May 7, 2008 | 01:35 PM
newblder's Avatar
newblder
Local machine shops should have some line reamers on hand. Maybe even adustable line reamers. If you can call around you might get lucky. It shouldn't take but a few minutes to line ream the holes and hone them in. I need to do the same on my truck so please keep us posted.
Old May 7, 2008 | 02:17 PM
rbaker6336's Avatar
rbaker6336
any good auto machine shop will hone them to fit the pins with an adjustable wet hone
takes about 15 minutes 30 if he screws around a bunch
Old May 7, 2008 | 03:18 PM
r_reed's Avatar
r_reed
i just had the old bushings removed, new ones pressed in, align reamed for my '49 f-1. , fit nice . at local machine shop/attached to a napa. it was $46 +tax. i know others have had it done cheaper, but i was ok with it. dick r.
Old Aug 19, 2022 | 02:51 PM
Ianmattf100's Avatar
Ianmattf100
I too am looking for the part # to the correct size reamer tool for a 59 f100.
Old Aug 19, 2022 | 03:28 PM
ALBUQ F-1's Avatar
ALBUQ F-1
A Sunnen hone prodices a better finish on the bushings, almost every real machine shop has one.
Old Sep 27, 2022 | 06:37 PM
lonewolf900's Avatar
lonewolf900
1st Gear
I sent my spindles out to be "professionally" fitted with new bushings.
They honed the bushings separately, fit felt good in both bushings but sloppy in each bushing
The bushing only had point contact with pin and would wear out quickly
I tried to explain to machine shop and played dumb
packrat56
Mar 4, 2007 10:02 AM
reamer
Jan 16, 2005 01:30 PM
Tugboatcap
Sep 15, 2001 09:47 AM
Rosati
Jun 8, 2001 08:26 AM
cccc1
Apr 20, 2000 07:22 AM
