cam retaining plate
Old Aug 7, 2001 | 08:12 PM
elsmith's Avatar
elsmith
cam retaining plate
I have a 360 the cam retaining plate is broke and I can't find another. Does any one know where to get one other than a junkyard? I got the block back from the machine shop they put sealed power pistons in it the number on the box is h395p it has four cut outs in the top what kind of compression ration is this going to have. I will get the casting# off the heads later.thanks Eric
Old Aug 8, 2001 | 08:46 AM
karljay's Avatar
karljay
cam retaining plate
If the block was zero-decked (pistons go to the top of the block) then I'd expect about 9.5:1 Most FE heads are in the 67~74 cc range.
If you can't find one in the junk yards, I'd try those "on the web" junkyards. I found one site that searches all over for the parts you want.
http://www.car-part.com/
They probably won't list the part, but it will give you a ton of phone numbers to call.
Old Aug 8, 2001 | 11:35 AM
bsprowl's Avatar
bsprowl
cam retaining plate
I've got one. What's you're adress?
Bob
bsprowl at bellsouth.net
919-303-6312
919-332-6312
'66 7 Litre, top loader, 3.25 Traction-lock, Sidewinder Intake, SCJ Exhaust
'88 F150 LWB 4x2, XLT Lariat, 302, 5 speed, 3.08
'99 Ranger, 4x2, 3.0, 5 speed, 3.73 posi
Old Aug 9, 2001 | 12:07 AM
elsmith's Avatar
elsmith
cam retaining plate
bob I e-mailed you with my address. Thanks. Is the stock ring gap the same for a 360 and 352? I know the bore is differant but my shop manual covers the 352 not 360. Thanks Eric
Old Aug 9, 2001 | 10:15 PM
bsprowl's Avatar
bsprowl
cam retaining plate
Didn't get your e-mail yet.
For the 360 its .015-.023 for the top ring, .010-.020 for the second and .015-.055 for the oil ring. All as stated in the '76 Truck shop manual.
Bob
Old Aug 10, 2001 | 11:09 PM
elsmith's Avatar
elsmith
cam retaining plate
[font size="1" color="#FF0000"]LAST EDITED ON 11-Aug-01 AT 00:10 AM (EST)[/font][p]I sent a message to your inbox. Is it bad to have the gap in the piston rings the same on the top and the bottom. They are with in specs toward the high end. Some are about .014 and others are about .020. I only checked four of them top and bottom. I am going to check them all tomorrow after I clean and paint the block. Thanks. Eric
Old Aug 10, 2001 | 11:27 PM
bsprowl's Avatar
bsprowl
cam retaining plate
I still haven't recieved an e-mail from you.
What in box are you referring to?
Bob
Old Aug 11, 2001 | 12:01 PM
elsmith's Avatar
elsmith
cam retaining plate
When you log in there is an Icon towards the top of the screen that says inbox and click on it. Eric
Old Aug 11, 2001 | 03:16 PM
bsprowl's Avatar
bsprowl
cam retaining plate
Learn something every day. Thanks. I'll get it off UPS second day on Monday. I've never had a ring gap that checked at less than middle of the spec.
Bob
Old Aug 11, 2001 | 09:12 PM
elsmith's Avatar
elsmith
cam retaining plate
The gap on the rings average about 18. Thanks. Eric
Old Aug 13, 2001 | 07:19 AM
donsboy's Avatar
donsboy
cam retaining plate
Old Aug 13, 2001 | 12:46 PM
bsprowl's Avatar
bsprowl
cam retaining plate
Darn and a bunch of lot stronger words.
I can't find it. Nor can I find the box its supposed to be in with two others and a bumch of misc. FE parts. I was certain I bought it what we moved from California. But after searching for several hours, nada.
No place else to look either. There should have been two spares, one from a 360 and another from a 428. As far as I know any plate from a 352, 360, 390, 410 or 428 will work. But I just don't have any.
I apologize for mis-leading you and stopping your search.
Bob
Old Aug 13, 2001 | 03:10 PM
elsmith's Avatar
elsmith
cam retaining plate
Thanks anyway bob. I guess I will have to check a couple of high performance shops and if they can't get it I will be looking through the wrecking yards.
