massive oil leak.!
Old Oct 9, 2007 | 10:03 PM
bdrummonds's Avatar
bdrummonds
either a pinhole in one ofthe HPOP braided lines, or the oring underneath the HPOP. what was the last thing you modded on the top front of the motor?
Old Oct 9, 2007 | 10:20 PM
crack's Avatar
crack
the last mod I did was the regulated return...I just thought of something...on sunday I rigged up a little boost leack checker...hooked it onto my intake...now could the air going in and no oil have messed up the O rings ?
Old Oct 9, 2007 | 10:27 PM
bdrummonds's Avatar
bdrummonds
Oh yeah, thats right you wanted to pump her up to 40PSI. the intake air and oil systems are seperate, so I doubt that happened.
But since you mentioned reg return, did you loosen any of the HPOP mounting bolts, when you removed the fuel bowl? If so then it may very well be the oring underneath the HPOP decompressed and shifted.
Old Oct 9, 2007 | 10:33 PM
crack's Avatar
crack
ha yea only pushed it to 30....I took out the 2 bolts that hold the fuel bowl in there....do these also hold the hpop in place?
Old Oct 9, 2007 | 10:40 PM
bdrummonds's Avatar
bdrummonds
I dont believe so, I think they are there simply to hold the bowl. but with all that close quarter work around those HPOP braided lines the leak has to be from somewhere up there.
Old Oct 9, 2007 | 10:42 PM
crack's Avatar
crack
yea, im gonna clean it up a bit tonight run it and see if i cant diagnose.
Old Oct 9, 2007 | 10:45 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Clean it all the way up, it will need to be done anyway. Then try to find it by cranking. Or you could start the truck and shut it down as quick as it starts. I will almost bet the farm your leak will reveal itself from a HPO source.
EDIT: Oh, I forgot to add, any leak in the engine area needs to be looked at from as far forward as possible. That fan will blow it back like nobody's business.
Old Oct 9, 2007 | 11:45 PM
crack's Avatar
crack
I checked the lines no real apparent leak there, I had it running for about 2 or 3 minutes and was under the hood looking around, found a drip into the engine valley just below the back side of the fuel bowl, is there anything hpop related back there...Im just in to put some not so nice clothes on...I'll wait a few minutes before I go leak searchin again.....thanks in advance
Old Oct 10, 2007 | 12:00 AM
Tenn01PSD350
A drip behind the fuel bowl is not a gusher like you desribed. The HPOP resides under the fuel bowl. If that is leaking, it will be far less pronounced at idle than at running pressure which can range from 2200 to 3000 psi. Check all of the fittings and plugs to the HPOP.
Old Oct 10, 2007 | 12:14 AM
crack's Avatar
crack
it appears to be a gusher when it fills up the valey and leaks over the bellhousing...but the source itself isn't a gusher, but its fairly consistant. I put a rag under the fuel bowl and let it run for a minute and pulled the rag out...coverd in oil, I just have to trace down where its source is..how many lines come off the hpop I checked the two most obvious ones and they dont appear to be leaking...are they supposed to havea bit of play?
Old Oct 10, 2007 | 12:18 AM
Tenn01PSD350
Make sure it is oil. You wouldn't be the first to have a fuel leak misdiagnosed as oil. Check the drain valve assembly on the fuel bowl very closely.
Old Oct 10, 2007 | 12:22 AM
1996pwrstrk's Avatar
1996pwrstrk
Theres a plug on the back of the HPOP that has a o-ring on that some times comes loose it did on mine . You may have to use a mirror and a flash light to see it with the fuel bowl on.
Old Oct 10, 2007 | 12:27 AM
  #28
crack's Avatar
crack
im pretty sure its oil. it has a bit of a fuel smell to it, but I think it might be mixing with a bit of the fuel in the valley from when I did the regulated return.....I think I know the plug your talking about...Ill get back to workin on it in the AM
Old Oct 10, 2007 | 12:32 AM
  #29
1996pwrstrk
This is the one I'm talking about.https://www.ford-trucks.com/forums/s...1&postcount=19
Old Oct 10, 2007 | 12:35 AM
  #30
crack's Avatar
crack
yea thats the one I thought aswell, I hope its something that simple!
