390 timing
Old Aug 22, 2001 | 01:02 AM
gtex's Avatar
gtex
390 timing
I just finished adding the following to my 390:
Edel RPM intake
Edel 750 Carb
Crower Power Beast Cam
Dynomax headers.
I've got the beast running and past the break in. However, it doesn't seem to like the vacuum advance. It runs better without the vacuum hooked to the distributor. I've hooked it to the same port that was attached to the intake manifold before. I've got the idle screw cranked in slightly (probably idling too high). I'm able to advance the distributor and get a smooth idle. Is that too far, considering I have a reasonably big cam?
Grind Lobe Center :292H/112D
Advertised Duration (Intake): 292, (Exhaust) : 302
Duration @ 0.50 in. (Intake) : 214, (Exhaust) :224
Gross Lift(1.76/1.76) (Intake): .521", (Exhaust): .547"
Any timing suggestions appreciated. I'm going to clean the "balancer?? (part with the timing numbers on it)" to see if I can read the timimg and see where I'm currently at.
Greg
Old Aug 22, 2001 | 01:24 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
390 timing
At first glance it would seem you have it too far advanced. But for it to alter the mechanical and vacuum advace that much seems odd.
It would also be difficult to start.
The usual settings are in the +8 to 12 degrees advance at idle with anywhere from +27 to 32 degree with the curve.
That is all without the vacuum hooked up.
With that cam the engine should easily idle below 700 rpm.
Maybe a vacuum leak somewhere?
Josh
Old Aug 22, 2001 | 08:19 AM
fairlaniac's Avatar
fairlaniac
390 timing
0ldman
29
Jul 7, 2014 09:32 PM
53fatfndr
Aug 26, 2004 10:55 PM
gtex
Nov 13, 2002 11:31 PM
gtex
23
Oct 6, 2002 04:08 PM
gtex
Feb 21, 2002 03:31 PM
