Ok so yesterday I was testing the holding power of several anchors. A little weird for school project but what even weirder was what my truck was doing. Every time we pulled an anchor the truck would have to work reasonably hard (about a 3000lb pull) right up until the anchor released. When the anchor released and 'popped' forward it would shut off. It would start right back up and run like nothing happened. This was on a warm engine and tranny. All of the gauges read normal and the truck is an automatic if that matters. Any help would be appreciated
I hate answer a question with a question but more info needed.
Does the truck shake violently when the anchor lets go?
How long are you pulling on the anchors before it lets go?
Does the check engine light come on?
You might be shaking something that is already loose. THere are couple things that I can think of that will kill the engine if loose.
CPS, cam position sensor Front of engine about 10 o:clock on the crank damper
fuse #9 & 22 under the hood
IDM, injector driver module. Driverside fender well
IPR, Injection pressure regulator. Front of engine hard to get to
Slim Chance but a possibility that since the IDM is not fastened securely something in there may have been loosened and looses connection. Just a thought.
Well that is the easy way out, but I still need to do some more testing. And since it it always seems to restart, it is mostly a strange mystery to solve
Cuda_Jim The truck dies instantly like the key was shut off
As far as speed: slow, like barely moving, maybe 1mph
Neal, Is there anything that is not solid state in the IDM like a relay or something that would be impacted by vibration or movement, other than the main harness which is tight
Maybe it need to be fastened better but I doubt it. The ground for the IDM is located on the driver side fender close to the firewall. It's a single black wire coming up out of a big harness.
Do you turn the key off then restart it? If so, this may be resetting what ever is gone bonkers (technical term). Scanning it right after it dies may give you some useful info. Leave the key on of course.
Get it scanned anyway, you may have a soft code that will get you pointed in the right direction.
ok so I took the long way home from work to see if I could get the truck to act up under any conditions. The only thing that caused the stalling was a hard pull up to 3k rpm in first gear and then completly letting off of the gas. If it shifted before letting off of the gas it was fine. Same with any level of acceleration other than full throttle. Not sure if this helps narrow anything down or just confuses things further.
And there was no need to turn the key off and then back on. Still no check engine lights, I'll have to see if the autozone here can scan a diesel, but I have never seen a check engine light come on in 6 plus months(except with just the key on)
