Power steering bracket
Old Oct 9, 2007 | 01:00 AM
65f100_352's Avatar
65f100_352
I'm doing a 460 swap in my 78 F250 and will the power steering pump bracket off the original 400 work?
Old Oct 9, 2007 | 02:14 AM
ErrorS's Avatar
ErrorS
I don't think so.. and since you can't use it you wanna sell me your old bracket?
Old Oct 9, 2007 | 04:42 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
There are TWO power steering brackets = support & adjusting.
The adjusting bracket is the same 351M/400/460.
The support bracket (D0AZ-3C511-F) is 460 only.
This bracket is also the same as 429 FoMoCo passenger cars 1970/72.
Old Oct 9, 2007 | 05:16 PM
65f100_352's Avatar
65f100_352
Got any pics of the one I need?
Old Oct 9, 2007 | 10:27 PM
masterbeavis's Avatar
masterbeavis
That has some sort of odd droop to it, lowering the pump. You would require a spacer and a bolt long enough to go thru the bracket, spacer.and at least 3/4" into the motor.
Old Oct 10, 2007 | 12:27 PM
Mil1ion's Avatar
Mil1ion
This is for Before 1978 so be careful what you get.
