Sponsored by: Real Truck
Is this bad?
Old Oct 8, 2007 | 08:21 PM
UGA33's Avatar
UGA33
Is this bad?
Have already taken it in to have it looked at and they said nothing is wrong its normal. It only slings fluid out while traveling at highway speeds. I washed the truck before heading to Tuscaloosa and this is what it looked like after driving 75mph for 213 miles:
Anyone have any ideas?
Old Oct 8, 2007 | 08:30 PM
msgtg's Avatar
msgtg
Well, having just read a owners manual regarding changing tires, there's a section that talks about lubricating part of each lugnut (NOT THE STUD!!!).
To me it looks like someone got a little sloppy with the lube and you're seeing the excess.
I recommend pulling out your owners manual and reading the section on changing tires.
Good Luck!
Joe
Old Oct 8, 2007 | 08:38 PM
UGA33's Avatar
UGA33
It would make sense now that i remember the problem didnt show up till after i had the tires rotated at a dealership in N. Carolina which was about a month ago. Guy must have put a ton on there! Appreciate the input.
Old Oct 8, 2007 | 08:41 PM
msgtg's Avatar
msgtg
You're welcome....is yours green over tan? Same colors I have on my 03 KR. I love it...easy to keep clean!
Joe
Old Oct 8, 2007 | 08:44 PM
UGA33's Avatar
UGA33
Its dark stone but it really depends on what time of the day you are looking at it b/c it can look green, brown, or black in different lighting
Old Oct 8, 2007 | 08:47 PM
i eat hybrids's Avatar
i eat hybrids
Mine does the exact same thing, but it even does it at forty miles perhour. I had it in for brakes not to long ago. He must of lubbed the crap out of somthing cause it annoys me. Now i have to carry a rag in the truck just to wipe it down
Old Oct 8, 2007 | 08:50 PM
UGA33's Avatar
UGA33
I hear ya on that one. It sucks to have a clean truck and lube running down all five spokes on the wheels. Drives me insane
Old Oct 8, 2007 | 10:42 PM
riggz's Avatar
riggz
I dunno man. Looks like you are leaking lug nut fluid. Could be dangerous!
Old Oct 8, 2007 | 11:13 PM
msgtg's Avatar
msgtg
OH NO!!!The infamous "Leaking Lugnuts"....Dr., is this fatal???????
LMAO!!!
Old Oct 8, 2007 | 11:40 PM
94yj's Avatar
94yj
Smile
next thing is the leaking wheel studs
Old Oct 9, 2007 | 04:11 AM
TNT in Round Rock's Avatar
TNT in Round Rock
very true !!! .. you can get more of that here : http://kalecoauto.com/index.php?main_page=index
Old Oct 9, 2007 | 08:18 AM
vettdvr's Avatar
vettdvr
When this happens you must use a new seal.
Old Oct 9, 2007 | 08:25 AM
redford's Avatar
redford
FTE Leadership Emeritus
Save the endangered lug nut seals.
Send your contributions to:
Save the Seals
C/O redford
PO Box 696969
Hooterville WI ou812
Old Oct 9, 2007 | 11:08 AM
i eat hybrids
It is getting annoying and i dont know how to stop it. Couple that with break dust. Now i have to wipe my rims down once a day before i start driving the truck
Old Oct 9, 2007 | 11:44 AM
vettdvr's Avatar
vettdvr
If this is due to lugs over lubed, you can remove them clean them with solvent, after dry put 2 drops of lube on the bearing surfact. Then reinstall.
This should clean it up.
