6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
holy smoke this engine rocks
Old Oct 8, 2007 | 07:59 PM
dt444e's Avatar
dt444e
I got ten thousand miles on my 08 F-350 6.4l. This truck is the strongest stock running truck I ever run down the highway. I been using my 2000 f-350 (7.3l) to allow my new truck to break in and holy crap ford finally got it right compared to my 6.0 (that was alright when chipped and programmed to the gill). The only thing is pulling a grade in West Virginia with 18000# on the ball(Fancy gap on I-77) my 7.3 would lose thirty miles per hour and run a little warm, and my 6.0 would run so damn hot it would go into limp mode(pretty embrassing). But this new one only lost twelwe miles per hour, and got 12mpg amazing I'm sold.
Old Oct 8, 2007 | 08:37 PM
jws316's Avatar
jws316
Smile
The last time I checked "Fancy Gap" was still in Virginia!
Old Oct 8, 2007 | 08:45 PM
SUPERDUTY_untouchabl's Avatar
I cant wait to see what people will do to these trucks once there warranty goes out. I mean performance wise.
mud rat jr.'s Avatar
mud rat jr.
Smile
I towed with my 08 for the first time on sat. small load only about 8000 l.b.s.total but it was between summit county co. and estes park co. (many small hills 11000-12000 ft.) was very impressed, ran 70-75 whole trip and got 13.9 (non reset lie-o-meter) ran like a beast. better than my turned up 7.3 so far I love my truck!
Old Oct 9, 2007 | 08:22 AM
fordfish's Avatar
fordfish
13.9 in the hills....what is your setup, Most nobody gets 13.9, most nobody runs 70-75 and gets any economy at all.
There must be some F'dup engine builders at IH, cause everyone of these engines is diff. From what I've read and get myself 10-12 empty 65 mph is the norm.
I know the territory your in and holding at 70-75 with that load at that fuel rate is well....YOU MY FRIEND HAVE THE BEST 08 FORD HAS BUILT TO DATE.
Congrats! ALso, 75 through Estes Park is almost suicidal.
Old Oct 9, 2007 | 11:22 AM
jasfaa's Avatar
jasfaa
8000 lbs total is the truck weight and a very light load. 13.9 mpg would be about right at this weight. If the load is the trailer weight then I would have to call B.S.
Old Oct 9, 2007 | 05:52 PM
Herbie02PSD's Avatar
Herbie02PSD
Check his original post on the 13.9 MPG... he states "non reset lie-o-meter". So using a lie-o-meter is going to give inacurate readings plus he did not reset his for that trip. Its NOT hand calculated so who knows what his exact mileage was??? Like the above poster I hightly doubt it was 13.9... more like 8-10 especially at that speed. In those hills maybe even less, who knows!
Old Oct 9, 2007 | 06:12 PM
HARDLUCKAUTO's Avatar
HARDLUCKAUTO
Talking
My truck pulled like no other but used fuel, but to be expected. My trailer is 15k 5th wheel and 3.73 f350 KR long bed 4x4 got 8.9 towing at 70. I got 7.5 towing at 80 in west Texas (which is the speed limit). It is 6.4 of course. 7.5 mpg.... could wish for more but 80 down the highway steady as a rock..... Would not change a thing.
Old Oct 9, 2007 | 09:15 PM
dt444e's Avatar
dt444e
be honest with you guys having a v-8 diesel is a cool thing but in mileage you pay for it by the fact of the rotational energy and BTU's that it takes to keep the beast rotating past 2000 rpms... If you could harness the low end torque through a good fuel curve that wouldn't make the transmission **** the bed you would have an efficient machine.
Old Oct 9, 2007 | 11:15 PM
NORTHLAND06's Avatar
NORTHLAND06
Talking
I pull almost 11,000lbs behind my truck I get about 8.0mpg at 65mph hand calculated. Was worse at 68mph about 7.0mpg but did even feel like it's back their unless their was bump in the road love it all power I need to pull my trailer down road. I would not own anything else but Ford PSD and SD!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Oct 10, 2007 | 08:19 AM
origcharger's Avatar
origcharger
The 6.7 Dodge/Cummins six cylinder peak horsepower is rated at 3013 rpm, so how is having a V8 spinning past 2,000 any more of a "penalty"??
Old Oct 10, 2007 | 10:41 AM
jasfaa's Avatar
jasfaa
Two extra cylinders is how and why the 6.4 gets worse fuel mileage but the Dodge Tranny is a serious POS so it is a trade off. Buddy has the Dodge and has already gone through three trannies. I think I take the fuel mileage issue on the Ford. Plus, it looks better.
Old Oct 10, 2007 | 11:20 AM
dt444e's Avatar
dt444e
origcharger,,, read my line again slooooooowwwwwly, I'm not talking horsepower... Talking losses with the factory fuel curve setting and the 6.7l or a 1935 John Deere can make as much horsepower as they want at 1000 rpm or 8500 rpm but it takes fuel and lots of it is used to make up for the losses through the extra rotating mass. Thats my point, power is a square function. If losses are 50@1000rpm then they're 200@2000rpm(just an example)
Old Oct 10, 2007 | 11:23 AM
origcharger
Originally Posted by jasfaa
Two extra cylinders is how and why the 6.4 gets worse fuel mileage .
Sorry, but I am not buying into that logic.
Old Oct 10, 2007 | 11:32 AM
origcharger
I read your line very slowly and you implied the V8 spinning past 2,000 rpm was costing fuel mileage over, I assume a six banger.
My point is how does a larger displacement six banger spinning past 2,000 rpm use any less? The longer stroke six cylinder should have more drag at a given rpm as the pistons travel more feet per minute.
