Hello,
My name is Aaron and I'm a Ford-o-holic! I'm a life long Ford fan in the middle of restoring my '78 F250 4x4. I also own a '72 Bronco that I use to trail ride and rock climb. I came across this site and joined to share in its infinate wisedom.
I'm located right in the middle if NC. My plans are to make a nice presentable truck I can take to the local cruise in or truck pull if I'd like. I will probably use it to pull my Bronco to the trail a couple times a year.
I'm working on putting the rolling chassis together right now. I have 400 with aussie heads, KB pistons, and Isky cam for power. It will be backed by the original NP435/205. I don't plan on much if any lift and running 33" tires. How about a couple pics...
I'll have to throw one in of my little Bronco too...
O what did it end up costing youi for those aussie heads? I need a to put a set on my 400 bad. They didn't have a shipment in when I rebuilt my 400. Thanks
