EGR removal
Old Sep 5, 2001 | 11:50 PM
FEina52F1's Avatar
FEina52F1
EGR removal
Old Sep 6, 2001 | 10:05 PM
Doop76's Avatar
Doop76
EGR removal
What's the effect if I remove my EGR (to include the carb spacer assembly) on my 76 F-100 360 and replace it with a generic spacer? Emission controls aren't a requirement here so I'm not concerned with that.
Thanks!
Doop <
76 F-100 Custom (96K Original North Dakota miles) 360-C6 All stock
64 F-250 (Bought from the north slope of Alaska) 292-T18 4 speed
Old Sep 8, 2001 | 01:08 AM
karljay's Avatar
karljay
EGR removal
If it sucks exhaust gas into the base of the carb, you should be able to seal it off without a problem. You might see a increase in power because the intake charge will be colder and cleaner.
Old Sep 8, 2001 | 07:21 AM
Charles-65F350's Avatar
Charles-65F350
EGR removal
The EGR is designed to dilute the incoming charge at part-throttle cruise, thus lowering peak combustion temperatures and reducing NOx emissions. It also allows more ignition advance for the same reason (lower peak temps, some non-burnable exhaust gas that helps prevent knock).
If it is functioning properly an EGR valve does not open at wide-open throttle so your peak power will not be affected anyway. But unless you have rejetted the carb and recurved your distributor (or at least installed an adjustable vacuum advance) you may have to retard your timing to prevent detonation at part throttle, so the net effect is actually to *lose* power and economy by simply removing it.
