Turn signal flasher
Old Oct 8, 2007 | 02:32 PM
Virto's Avatar
Virto
Turn signal flasher
Stupid me, left my Chilton's at home so hopefully I can be steered in the right direction...
Noticed this morning that my turn signals weren't working. Got a couple of weak flashes and then dead as a doornail. The hazard switch still flashes the lights. I did notice that if I use the turn signal lever and I'm standing on the brakes, the brake lamps go out.
My LTD had a flasher unit for the turn signals and a seperate one for the hazards. Anyone know if these trucks are the same? Hopefully I can just swing out and pick up a new flasher (pleeeeeease don't be the turn signal switch).
Old Oct 8, 2007 | 02:35 PM
tomtoc's Avatar
tomtoc
not sure about your 90, but my 97 (same as 96), the turn signal one is in front of your knees in the fuse box. the hazard one is under the dash direclty behind it
Old Oct 8, 2007 | 02:37 PM
17fordguy's Avatar
17fordguy
my 96 f150 has 2 separet ones
Old Oct 8, 2007 | 02:56 PM
Virto's Avatar
Virto
I had a feeling it was something like that. I have the fuse panel at home so I didn't have the diagram to be sure what I was looking at.
Flasher was like 12 bucks way back when for my LTD...I assume this is about the same.
Old Oct 8, 2007 | 03:00 PM
tomtoc's Avatar
tomtoc
$12 would be the expensive heavy duty one. i grabbed a couple for about $3 each. its up to you which one you want to buy. some swear by the HD ones, but i can buy several of the regular ones for that
Old Oct 8, 2007 | 03:17 PM
Virto's Avatar
Virto
HD you say?
Naa, forget that. I'm sure the floor will rust thru and the truck will split in half before another flasher unit dies on me.
Old Oct 8, 2007 | 06:02 PM
rikard's Avatar
rikard
The HD ones are usually for the guys that haul trailers. A standard flasher will have trouble with the additional load of added bulbs and flash at faster rate.
regards
rikard
Old Oct 9, 2007 | 11:34 AM
Virto's Avatar
Virto
The standard flasher and hazard flasher are interchangeable (ie, the exact same) right? NPD lists one unit for both applications.
I should be able to just run out and swap them and see if that's the cause of my problems, right?
Old Oct 9, 2007 | 11:36 AM
tomtoc's Avatar
tomtoc
again, not sure about your 90, but my 97's are interchangeable
Old Oct 9, 2007 | 11:53 AM
Virto's Avatar
Virto
Yhea, I'm willing to bet they're exactly the same...don't know why I can never put 2 and 2 together in my head these days, I must be losing it.
Thanks guys, I'm going to run out on lunch and see what the deal is.
meporsche
Apr 3, 2016 04:05 PM
Crash55
19
Sep 30, 2015 08:12 AM
pauldfixr
Aug 28, 2015 07:50 PM
adrianspringerpc
Mar 11, 2014 07:42 AM
Fishin76
Jan 8, 2010 05:57 PM
