brake fluid leak
Old Oct 8, 2007 | 06:22 PM
nobodyspecial's Avatar
nobodyspecial
You make a good point though, about the safety factor. Like i said before, you wouldnt replace just a few lines to have another break while you are driving, doing a hack fix like that is even worse.
Your life is just not worth it, do it right!
Old Oct 12, 2007 | 02:39 PM
sparkyrhett's Avatar
sparkyrhett
i replaced the brake line now i am trying to bleed the brakes. i have been putting pb on the bleeder valves to lub. the rear bleeder valves take a 3/8 wrench, the front should be the same right. i can't find a wrench that will fit. the 3/8 to small, i even tried 10mm, 11mm. what am i missing here. anybody?
thanks in advance
Old Oct 12, 2007 | 06:08 PM
jroehl's Avatar
jroehl
If the 3/8 wrench isn't fitting, your bleeder valves are probably dirty and/or rusty. Scrub them with a stiff wire brush and some PB, Rust-Eater or WD40. You can even carefully use a small metal file. In my experience, they either open relatively easy or they break off...
Jason
Old Oct 12, 2007 | 06:17 PM
quicklook2's Avatar
quicklook2
i think they are metric, i do not remember what size at the moment.
a six point socket is the only way to go.
Old Oct 12, 2007 | 06:19 PM
jroehl's Avatar
jroehl
Flare nut wrenches work pretty well, too...
Jason
Old Oct 12, 2007 | 06:30 PM
quicklook2's Avatar
quicklook2
i find them very hard to get into the rear brake drum area and if rusted they sometimes do not work.
i of course have a set of them.
but i use a 1/8" drive and sockets for brake bleeding.
Old Oct 12, 2007 | 06:46 PM
nobodyspecial
As opposed to a five point socket? hehe, just kidding
Old Oct 12, 2007 | 06:55 PM
quicklook2's Avatar
quicklook2
5 point sockets are for mopars.
Old Oct 12, 2007 | 07:12 PM
jroehl's Avatar
jroehl
...or for turning the water valve in your meter pit...
Jason
Old Oct 12, 2007 | 07:14 PM
jroehl's Avatar
jroehl
Oh, and I've never seen a 1/8" drive socket/ratchet...I'm sure you meant 1/4"...
Jason
Old Oct 12, 2007 | 07:42 PM
quicklook2's Avatar
quicklook2
no, i mean 1/8" socket set.
look here for an example.
http://www.overstock.com/Home-Garden...4/product.html
Old Oct 13, 2007 | 06:03 AM
jroehl's Avatar
jroehl
1/4", 3/8", 1/2", no 1/8".
Jason
Old Oct 13, 2007 | 09:58 AM
  #28
quicklook2's Avatar
quicklook2
brain fart.
was at a funeral on friday and the brain was not working right.
Old Oct 13, 2007 | 11:18 AM
  #29
jroehl's Avatar
jroehl
My condolences. I just like having/knowing about tools...
Jason
Old Oct 13, 2007 | 11:28 AM
  #30
quicklook2's Avatar
quicklook2
thanks, i was drinking and watching the cleveland indians get beaten and the brain was shorting out.
