Sponsored by: Real Truck
Factory tailgate missing key
Old Oct 8, 2007 | 12:37 PM
jopiel's Avatar
jopiel
I recently purchased an 02 F250. I assumed that the ignition key would work on the tailgate lock but I was wrong. What should I do so I can lock my tailgate? How do I get a key for it? Or do I need to have a new lock cylinder installed?
Old Oct 8, 2007 | 12:48 PM
rbaker6336's Avatar
rbaker6336
tailgate must be replaced,ignition key is supose to fit lock
Old Oct 8, 2007 | 12:49 PM
redford's Avatar
redford
FTE Leadership Emeritus
Yes, it should be the same key as your ignition.
Old Oct 8, 2007 | 12:54 PM
2008drkstone's Avatar
2008drkstone
past owner must have replaced tailgate due to damage. probably you might have to get new key for it
Old Oct 8, 2007 | 12:56 PM
redford's Avatar
redford
Does your ignition key fit your door locks?
Old Oct 8, 2007 | 01:10 PM
aldridgec's Avatar
aldridgec
You might be able to go to ford with the vin number and proof of ownership and have a new lock cylinder keyed alike, or have them key it to your current key and update the database if it isn't the original key. The cylinder itself is pretty easy to change. You may be able to have a locksmith rekey it to work with your key as well. You have options.
When I got my new bed, I was being really **** when I removed the tumblers from the old lock and put them in the new lock so everything would be as new as possible!
Old Oct 8, 2007 | 01:44 PM
Beerstalker's Avatar
Beerstalker
Before you go through all that, take the hadle apart and try cleaning out the lock. It might just be dirty enough inside that it can't turn.
Old Oct 8, 2007 | 02:30 PM
fordboy2's Avatar
fordboy2
spray some wd-40 in the lock everyday for a week, if its got crude in there and has not been used it will bind just keep workin it and it will probably free up.
Old Oct 8, 2007 | 02:51 PM
rbaker6336's Avatar
rbaker6336
I like to use the straw to stick it in and give it a good washing
