Sponsored by: Real Truck
Stainless Steel HELP!
Old Oct 8, 2007 | 10:29 AM
Storm's Avatar
Storm
Hey gang.. I need to find a 90 degree Stainless Steel elbow for my boost line.. I went ahead and switched to the 05-07 Accufab polished intake elbow and need to get an elbow that matches for the boost line instead of the stardard copper..
Thanks!
Old Oct 8, 2007 | 11:01 AM
thedaddycat's Avatar
thedaddycat
Try a plumbing supply house, and have your wallet ready....
Old Oct 8, 2007 | 11:12 AM
Storm's Avatar
Storm
There was a place online that had em.. I just cant remember the name.. They were pretty cheap too.. Bear Hunter has one.. Yet he hasnt logged in since August 1st Think he's playing Ranger right now..
Aye.. Copper/Polish just won't mix..
Old Oct 8, 2007 | 11:24 AM
I H8 GM's Avatar
I H8 GM
Do you know what the size is?
Old Oct 8, 2007 | 11:27 AM
Storm's Avatar
Storm
It's a 1/8" NPT 90* elbow im looking for
Old Oct 8, 2007 | 11:43 AM
I H8 GM's Avatar
I H8 GM
NPT on both sides, like this?
http://www1.mscdirect.com/CGI/NNSRIT?PMPXNO=5569929&PMT4NO=30522068
or a compression fitting on one end like this?
http://www1.mscdirect.com/CGI/NNSRIT?PMPXNO=7184663&PMT4NO=30522548
Old Oct 8, 2007 | 11:50 AM
Storm's Avatar
Storm
Found it.. Article was on Truck Blog that had the one Bear Hunter got..
Part #: SS-200-2-2, SS Swagelok Tube Fitting, Male Elbow, 1/8 in. Tube OD x 1/8 in. Male NPT
Theres a place in Austin that carries it, paid $10 bux for it
Old Oct 8, 2007 | 12:03 PM
rbaker6336's Avatar
rbaker6336
http://www.buyfittingsonline.com/
Old Oct 8, 2007 | 01:29 PM
75F350's Avatar
75F350
The Swagelok fitting is a nice fitting. There are many equals that are less expensive, but you are onlu looking for one, so it is not too bad.
This fitting uses two pieces that act as the crimp during the compression process. The tappered, or cone shaped one is a no brainer, but the second little ring that looks like a washer has a step that is directional, and must not be installed upside down, or it will leak. Inspect the material before you install it, and you will see a small tapper on the little ring. you will also see this tapper in the other end where it seats. Do not loose this when you take it apart. Many of my guys have installed these upside down, and the majority have leaked.
Just a littlt heads up on this style fitting, since they only send one set of crush sleeves with each fitting.
