More on the continuing saga of the Bad IDM
I just spoke with the dealer who diagnosed the bad idm problem on my F350. He confirmed that, yes they plugged in a known good idm and was able, therefore, to get the scan code that told them #4 injector was bad. He said that if #4 was bad then the engine would run as though several cylinders were not firing. I can't imagine 1 cylinder causing the problems I am having. Can anyone confirm this? Isn't the ECM, or is it a PCM, responsible for scanning and displaying codes? Wouldn't it have generated a Bad IDM code? I don't know where to go with this. I guess I have to find an injector today and replace it after I test the fuel pump for proper pressure. I don't suppose that is a big deal, but am I just throwing parts at the truck till somethiing works? I guess I have no faith in the dealer and just need some supporting info from experts here.
Can't get a difinitive answer from the dealer. He guaranteed that if the IDM and injector #4 was replaced truck would run like new. I'm done ini. I guess I have to change the injector out. Once I have completed the tasks I will probably be told that since I am not a Ford Certified Diesel Mechanic that I did the job wrong therefore it wont be fixed. I just have to keep throwing parts at this thing till it's right. Now I have to find the special tools required to remove and install the injector. The procedure seems simple enough even if it does take many hours. What with removing oil drain plugs, diesel drain plugs freaking out to make sure there is no fuel or oil pouring into the cylinder etc.
I can't read the codes because I need a special computer to do an engine running scan. The new IDM didn't do squat. Well that's because it is a "combination of IDM and injector". Why do I get a feeling I need a bath?
Originally Posted by Action4478
Have the dill hole check the UVCH's first...Was It a 1316?....
Read this --http://www.forddoctorsdts.com/articles/article-05-10.php Good luck.
