no power 99 7.3
Old Oct 7, 2007 | 10:55 PM
fireeater91's Avatar
fireeater91
Unhappy no power 99 7.3
i have a 99 psd 7.3, got water in fuel messed up injectors, took it to get scanned trew up injector 2 and 4 out. I got 2 injectors installed, now i don't have any pickup, very slow take off! I put new glow plugs also. might it be my valve cover gasket>? it will run 70 or 80 on the highway but take off is very slow if i floor it it will not accerlerate fast once i go over 40 it will gradully go. i also put a new fuel filter with diesel kleen. can anyone help with problem? thanks rob
Old Oct 8, 2007 | 07:28 PM
F350-6's Avatar
F350-6
Sorry this ones over my head. Are you sure it only fouled 2 injectors? Have you had any codes read since the new injectors were installed? Maybe someone else with more knowledge will chime in.
Old Oct 8, 2007 | 07:34 PM
bdrummonds's Avatar
bdrummonds
It can take up to a few days after changing injectors to work the air out of the oil galleys. drive it for about 100 or so miles and then you will start noticing better get up and go.
only other thing I can think of is loose upipes, or maybe low oil.
ALL-SEASON'S
16
Feb 15, 2019 10:59 AM
GRoke7.3
32
Jan 5, 2015 10:21 PM
Slankky
Nov 6, 2011 09:02 PM
rebelrunner
Nov 14, 2004 10:49 PM
emyth
Jul 28, 2004 09:32 PM
