Offroad & 4x4
Full time hubs?
Old Oct 7, 2007 | 08:29 PM
Andy's '79's Avatar
Andy's '79
Full time hubs?
Does anyone keep their hubs locked for long periods (hunting season)? What would happen if I did? I don't ever get over 50 mph anyway.
Old Oct 7, 2007 | 08:36 PM
MBBFord's Avatar
MBBFord
I don't unlock mine very often. I've done 60 mph several times with my hubs locked in and the t case in 2wd. No big deal.
It slightly causes things to wear faster since the front driveshaft will be spinning, hubs are engaged, etc.... but it keeps the t case properly lubed, and when you get in a bind, all that's requried is a pull on a handle and your good to go. Instead of getting out in some mud and locking them in, then covering the floor with mud.
It wouldn't be advisable to do 70mph + every day a couple times a day, but 50 won't hurt anything.
Old Oct 7, 2007 | 08:46 PM
quadzjr's Avatar
quadzjr
just another Rockwell looser
i wouldn't recomend it....just b/c of the wear.....but if there is anything uhh......sketchy about your front drivetrain....you'll feel it/ hear it...
Old Oct 7, 2007 | 08:52 PM
MBBFord's Avatar
MBBFord
One of my friends front driveshaft isn't balanced to good, so when he would lock them in a do 55 he had a vibration, but still no harm, but if it's out of balance, then it isn't worth the vibration.
Old Oct 7, 2007 | 09:07 PM
75F350's Avatar
75F350
A balance problem is a mechanical problem that should be fixed anyway.
Many guys suggest that leaving the front hubs engaged wears out parts. How is this possible? A ful time 4wd does not wear anu parts any faster, nor does the rear axle wear quickly, or even any faster because it is used every time the truck needs to move.
Guys can expect over a hundred thousand miles out of a rear axle that has power to it every one of those miles, so why would we not expect the front to be able to do the same?
I believe most front axles go bad from lack of use.
Plenty of guys lock em in the winter and free them during summer. Pretty sure you will not see any damage or "additional wear" from this.
Old Oct 7, 2007 | 09:25 PM
quadzjr's Avatar
quadzjr
that makes alot of sense....but.....uhhh.....well......hmmmm.....but. ....
Old Oct 7, 2007 | 09:29 PM
quadzjr's Avatar
quadzjr
thats how i found out how bad my front dshaft was off balance....but since i only used in off road i didn't worry about it.....it was a trigger to know if my hubs were still locked in when i felt the shakin....haha
Old Oct 7, 2007 | 09:56 PM
75F350's Avatar
75F350
Did you post a pic or somethin? I can't see anything....
Old Oct 7, 2007 | 09:59 PM
tatonka04's Avatar
tatonka04
Dude I,ve never thought of it that way! That makes too much sense. It can't be right.
Old Oct 7, 2007 | 10:03 PM
khadma's Avatar
khadma
Carpenter Local 745
I'm gonna lock mines tonight and see what happens
Old Oct 7, 2007 | 10:21 PM
quadzjr's Avatar
quadzjr
no i was lame i thought that the having to scroll down to see the ban sign was cool....your right.....i was wrong...
Old Oct 7, 2007 | 10:31 PM
godblessmud's Avatar
godblessmud
it will slightly eat gas mileage...but i keep mine locked in winter because it keeps me from freezing my *** off in a snowstorm trying to lock my frozen solid hubs...
Old Oct 7, 2007 | 10:33 PM
MisterCMK's Avatar
MisterCMK
Nope, won't cause a problem other than less fuel mileage. I leave mine locked in most of the winter and not a problem. The t-case will always be lubed as its always spinning even if the fronts aren't locked.
Old Oct 8, 2007 | 08:07 AM
RogueSpear2023's Avatar
RogueSpear2023
Lock them in I leave mine locked most of the winter, because up here in MN you never no when you will need 4wd, and if you don't put it in you someimes get into trouble to fast. The only thing I've noticed is you get about 1 mpg a less.
Old Oct 8, 2007 | 08:37 AM
MBBFord's Avatar
MBBFord
With my NP203 and part time kit, it was required to lock the hubs in and drive around. In order to lube a passage way that only gets fluid to it when in 4wd, and if this wasn't done, after a while your bearings and seals would be needing to be replaced. This is on the 203 though.
