Battery Light
Old Oct 12, 2007 | 04:08 PM
79F150EFI's Avatar
79F150EFI
I ad the same issue before. It would occasionally flicker...but only at idle. Maybe twice a week. I carried a voltmeter with me, but I couldn't get the hood popped soon enough to see alternator output voltage. It would literally flicker for a few seconds and stop.
I continued to drive the truck for another two months. Then the alternator totally failed. I would venture to guess that if your connections are good, your alternator is slowing failing.
Old Oct 12, 2007 | 07:37 PM
brushfit's Avatar
brushfit
casey,also make sure your belt routing is correct it will go on seemingly tight in different configuration happened to me r&ring w-pump in 30 below weather(i may have been in a hurry sheeeze)also some auto stores carry the cheap rebuilt alt,such as champion brand got tired of changing those out,,,boiling battries at first then surge charging,,,,shucks seems to have a good brand mines been in for 2 years without any fluctuation dont have to clean batteries near as often.
Old Oct 13, 2007 | 02:29 AM
RubberDuck's Avatar
RubberDuck
Okay, even if the connections are good. Pull the regulator off the back of the alt and look at where the brushes ride. If the shaft is worn down, it's alt time. But if not, I would throw a regulator at it. At least that's what I would check next.
Old Oct 13, 2007 | 04:10 PM
caseydudem's Avatar
caseydudem
Well I'm still trying to get to that regulator, being on such long shifts isn't helping. I fill you all in as soon as I can get a look at it.
Old Oct 14, 2007 | 10:59 PM
Randy Pederson's Avatar
Randy Pederson
In the kit I bought to repair my alt it states on top in red letters that these alts tend to burn and break certain wires. I checked and found that was what had happened to mine. Unfortunatly they tell only after you've opened the kit and can't return it.The copper wires that broke on mine were at the frt and could be seen with a flashlight without opening up the case.
Old Oct 19, 2007 | 08:36 AM
caseydudem's Avatar
caseydudem
Thumbs up Its off
Originally Posted by RubberDuck
I say go back to the three wire connector. Pull it, and remove the red lock, pull the pins out, clean them and squish them a little. I had the same problem. Light would flicker sometimes, but the gauge still showed charging. Take the connector apart and clean it, even if you think it's good. That's my bet.
Rubberduck is the man with the million dollar answer. I did this fix just this mourning and my light went off. Hopefully it stays off. Thanks for all the help
Old Oct 19, 2007 | 08:11 PM
RubberDuck's Avatar
RubberDuck
Sounds good man. I'll bet you won't see that light anymore. Glad I could help.
tjbradney
13
Dec 22, 2015 07:56 PM
IttyBittyX
Jan 13, 2015 10:41 PM
dandzivi
2004 - 2008 F150
Feb 7, 2014 06:33 PM
dwildey
Jun 13, 2010 04:30 PM
slparks
Electrical Systems/Wiring
Aug 25, 2007 08:40 AM
