PLEASE explain - auxiliary fuel port?
Old 10-28-2007, 03:20 AM
szpieleusa's Avatar
szpieleusa
szpieleusa is offline
I saw it on ford specs sheets and dont know exactly what it means - that i can add the second gas tank??? or something else?
Thanks for reading and hope for answer
Old 10-28-2007, 05:22 AM
VikingBabe's Avatar
VikingBabe
VikingBabe is offline
Probably. My van was built for commerical use and came with dual tanks. But not all came with this. Some only came with one. So there would be an area for an extra tank if you want to install one.
The 22gal main tank is the rear. The 18 gal auxillary is a seperate tank on the driver's side.
Old 10-28-2007, 07:47 AM
subford's Avatar
subford
subford is offline
The auxiliary fuel port is for E-series RV to run the AC generator and for cargo or chassis-cab models only. It's only use that I'm aware of is so one could run gas-powered equipment from the van's fuel tank (commercial and RV use only).
Old 11-05-2007, 07:07 PM
MuddyAxles's Avatar
MuddyAxles
MuddyAxles is offline
What subford said:
That's what the dealer told me when I asked...but I'm not sure the Quigley replacement tank has this, even though I paid for it on the original, pre-Quigley tank.
Diesel 724
02-04-2015 09:15 PM
Dmoe512
6.7L Power Stroke Diesel
06-29-2014 10:23 AM
Lukeit
2004 - 2008 F150
05-03-2014 10:28 PM
TheRifleman
Electrical Systems/Wiring
01-20-2014 01:34 AM
schmity
30
06-27-2008 03:22 PM
Quick Reply: PLEASE explain - auxiliary fuel port?
