need to replace washer fluid pump
Old Oct 6, 2007 | 11:08 PM
boggerted's Avatar
boggerted
Ok have a 84 f250 with 351w. I was troubleshooting why my wiper fluid wouldn't come out. So, to test the wiring, I hooked up my test light to the little prongs in the connector that goes on the pump itself and one of the two would turn on when i pushed the **** in, so i figure the wiring and switch are good. However, since the pump doesnt work, i guess i need a new pump. BUT HOW DO YOU GET THE OLD ONE OUT???? It looks like it has some retarded ring around it, but instead of forcing it off and breaking it, id ask here first. Thanks in advance
Old Oct 7, 2007 | 12:35 AM
Sycostang67's Avatar
Sycostang67
Thats it, just get in there with a small screwdriver or pick and pry the ring out. The new pump should come with a new ring. Mine did anyway.
Old Oct 7, 2007 | 02:50 AM
howler's Avatar
howler
with the older trucks the washerfluid/ overflow tank can get very brittle... I've gone to the boneyard and bought the whole unit, so I don't have to make an extra trip to get a new tank
Old Oct 7, 2007 | 10:34 AM
cfrives3's Avatar
cfrives3
It is fairly easy to fix, just have to be careful with it. I used a little vaseline to help things go together and seal up.
Old Oct 7, 2007 | 12:07 PM
blue beast's Avatar
blue beast
You can leave it in place and just get a aftermarket one if you think the tank will crack. it will pull through the old pump.
Jeff Meszaros
Feb 16, 2017 09:42 AM
PapaHepcat
Aug 8, 2015 03:28 PM
CapeFear562
Large Truck
Apr 11, 2015 03:39 PM
sigtauenus
Apr 2, 2010 11:30 AM
mattklionsky
1997 - 2003 F150
Aug 2, 2001 11:00 PM
