Need tech advice
Old Oct 6, 2007 | 06:28 PM
SLEEPER1's Avatar
SLEEPER1
Need tech advice
I have a 1993 F-350 7.3 diesel with a E4OD previously had hard shift now will not shift will manually not automatic any suggestions?
Old Oct 6, 2007 | 07:30 PM
JLDickmon's Avatar
JLDickmon
trans shop
needs pressure diagnosis
might be simple
throttle valve pressure problem?
how long has it been since you dumped the fluid and changed the filter?
Old Oct 6, 2007 | 08:14 PM
kcb37's Avatar
kcb37
See what your fluid looks like. If it is bad you can try that. Probably going to be something internal though.
