need tech info
Old Oct 5, 2007 | 09:41 PM
mcochrane's Avatar
mcochrane
need tech info
looking for some help with my 90 F150. trying to find why I am burning so much fuel Any suggestions would be helpful
mike
Old Oct 5, 2007 | 10:10 PM
foobarbigtime's Avatar
foobarbigtime
Do you have the 5.0 litre? What tranny you have? My 87' is the 5.0 litre with the C6 tranny no overdrive and it revs quite a bit just doing 100km/h, she is a pig on gas for sure, maybe 400kms per tank. It sure does'nt go far when your tank is only 70 liter. A lot different from the 1994 T-bird with the 3.8 liter engine. I'm getting 600 - 700kms to a 70 liter tank with that car and it had 390,000kms on it.
Old Oct 5, 2007 | 10:13 PM
mcochrane's Avatar
mcochrane
It's the 5.0 and AOD trans.
Old Oct 6, 2007 | 02:37 AM
red58's Avatar
red58
has ya truck had a tune up lately,plugs timing,air and/or fuel filters,is the auto ok, shifting ok and not slipping,exhaust ok no blocked cats, starting with a tuneup is easiest all these can effect your fuel economy,hope this helps bud
Old Oct 6, 2007 | 02:44 AM
khadma's Avatar
khadma
Carpenter Local 745
1990? original engine - original 302 - maybe time for a rebuild if it has not had one already- will low compression rob an engine of MPG?
Start with a tune up and if the budget allows freshen up the internals of the 302.
Old Oct 6, 2007 | 12:42 PM
Conanski's Avatar
Conanski
What milage are you getting specifically? Any bad sensor will affect milage. Pull the codes first. If that doesn't show anything then tell us how it runs besides having bad milage.
Old Oct 6, 2007 | 01:09 PM
quicklook2's Avatar
quicklook2
you need to give a whole lot more info before any useful suggestions can be made.
Old Oct 6, 2007 | 08:41 PM
kcb37's Avatar
kcb37
Did you just buy this or have you owned it and the mileage gotten worse. The different transmissions and differentials affect gas mileage greatly.
iwanaflattie
Jul 17, 2012 09:14 PM
Tennessee Chapter
16
Nov 7, 2002 06:35 PM
Lashlaroo
Oct 19, 2001 09:07 PM
bn
1978 - 1996 Big Bronco
Sep 13, 2001 07:41 PM
jakegypsum
Apr 24, 2001 11:34 AM
