Main Stud problem.
Old Oct 22, 2001 | 02:12 PM
Ratsmoker's Avatar
Ratsmoker
Main Stud problem.
I used main studs for my 390 because they were the same price and they are stronger so I figured why not? I had the block line honed with the studs also. Went to put the original 428CJ windage tray and oil pan on the other day and noticed the number 5 main studs won't allow this to happen. I have been told by some to grind the studs & nuts and told by others to replace them with the original ford bolts. Not real crazy about grinding the studs and nuts. I am also not worried about the stock bolts breaking, but I am worried about the stock bolts throwing off the line bore. Any ideas. It's always the little things that get ya!
Old Oct 22, 2001 | 04:44 PM
dinosaurfan's Avatar
dinosaurfan
Main Stud problem.
Rat, this one is easy. you can either dimple the tray with a ball peen hammer, or if you need more room, use a hole saw and cut some holes in the tray where the studs hit. DF
Old Oct 22, 2001 | 05:00 PM
Ratsmoker's Avatar
Ratsmoker
Main Stud problem.
[font size="1" color="#FF0000"]LAST EDITED ON 22-Oct-01 AT 06:01 PM (EST)[/font][p]I can easily modify the windage tray to fit but the nut and the stud are stopping the pan from going on. I don't think I could beat a big enough dent in the pan to clear them without going through it. The actual gasket surface of the pan is stopping it from going on. I have been told that most people cut the part of the cap where the nuts clamp down so the nuts are below the bottom of the cap but its too late now.
Old Oct 22, 2001 | 07:48 PM
FE427TP's Avatar
FE427TP
Main Stud problem.
What about taking a torch to the pan and getting it nice and warm then tightening it down to the block with it still hot enough to bend the pan? if you had something under the heads of the oil pan bolts to keep the pan rail straight it might work. I'll probably have to figure this out too when I get my 410 to that point.
Old Oct 25, 2001 | 05:29 AM
Ratsmoker's Avatar
Ratsmoker
Main Stud problem.
I think I figured it out. I don't know if you are using a windage tray 427TP but if I use the thick felpro gasket and the original 428 CJ tray whick is pretty thick for a windage tray along with the other thick gasket the oil pan completely clears the nuts and only needs slightly adjusted to clear the rest of the stud. Should work out. Heads will be in Monday so I'm gettin pretty stoked.
Old Oct 25, 2001 | 03:37 PM
390fe's Avatar
390fe
Main Stud problem.
mustang_gt_350
Apr 4, 2011 05:13 PM
Chaosracing
Modular V10 (6.8l)
Mar 5, 2011 08:57 AM
maxtor
Apr 16, 2009 01:33 PM
AFterMidnight
Feb 27, 2006 04:56 PM
Capone
1978 - 1996 Big Bronco
Mar 29, 2005 01:04 AM
