headless
Old Oct 6, 2007 | 10:44 AM
gb'sfx4's Avatar
gb'sfx4
old enough to know better
headless
when will heads for the 6.0 be available again.
my truck is down for the count til some turn up.
Old Oct 7, 2007 | 07:12 PM
Maxium4x4's Avatar
Maxium4x4
Did you try to order a set? Are your old ones trash? You can have a machine shop resurface the heads, I took .009 off of mine and that is the limit. Ford specs are .002
Old Oct 7, 2007 | 07:18 PM
WishIhada7.3's Avatar
WishIhada7.3
are they warped enough they can be shaved??
Old Oct 7, 2007 | 07:22 PM
yamaguy's Avatar
yamaguy
why are they not available? thats not a good idea on ford/International's part.
Old Oct 7, 2007 | 09:20 PM
mulot30th's Avatar
mulot30th
Wow... I would have been pissed off if I decided to order a set of heads and they were not available...
Old Oct 7, 2007 | 09:21 PM
cyrexpl's Avatar
cyrexpl
You're kidding, there are no heads available from International/Ford for the 6.0? Wow. I hope the heads on my truck, which is in service, are ok otherwise I'm SOL.
Old Oct 7, 2007 | 09:30 PM
gb'sfx4's Avatar
gb'sfx4
I had the heads replaced with reman. ones and developed a problem within 600 m.
there are certain heads that have been recalled, mainly the ones I put on my truck
and now the entire stock with a certain mfg. date.
so from what I hear demand far exceeds supply
Old Oct 7, 2007 | 11:29 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
We have several sets sitting in stock.
When do you need them?
Old Oct 8, 2007 | 07:23 PM
gb'sfx4's Avatar
gb'sfx4
they are going to have to come from the dealer since they are replacing the ones that were *****, but I'll keep that in mind
thanx
Old Oct 8, 2007 | 10:29 PM
riggz's Avatar
riggz
I just had one head replaced on my 6.0L a couple weeks ago.
Old Oct 8, 2007 | 11:18 PM
gotfu's Avatar
gotfu
Does anyone know what was wrong with all the heads? Why the recall?
Old Oct 8, 2007 | 11:48 PM
blackhat620's Avatar
blackhat620
There was a batch of remanufactured heads and blocks that did not pass spec.
STOP SALE and Quarantine stock of 3C3Z-6049-CARM 6.0L Heads and 6.0L Reman Engines
Date: Sept 19, 2007
Subject: Stop Sale and Shipping Instructions for:
1. Remanufactured 6.0L Head, part number 3C3Z-6049-CARM
2. 6.0L remanufactured engines
URGENT – IMMEDIATE ACTION REQUESTED – STOP SALE and Quarantine stock of 3C3Z-6049-CARM 6.0L Heads and 6.0L Remanufactured Engines
BACKGROUND
A manufacturing concern has been found in some Remanufactured 3C3Z-6049-CARM 6.0L Heads and some Remanufactured 6.0L engines.
This concern could reduce customer satisfaction.
1. ACTION REQUESTED - HEADS
Isolate and quarantine all stock part number 3C3Z-6049-CARM with package label date codes prior to 8/31/07, and contact your Powertrain Distributor to coordinate an exchange.
Resume sales of all stock of 3C3Z-6049-CARM with a package date code of 8/31/07 and later.
See attachment for picture of label and date location.
2. ACTION REQUESTED - ENGINES
Isolate and quarantine all stock on hand of the part numbers below with package label date codes from 6/28/07 through 8/7/07, and contact your Powertrain Distributor to coordinate an exchange.
Resume sales of engines with package label date codes that fall outside the 6/28/07 to 8/7/07 window.
6.0L (Long Blocks)
3C3Z-6006-AARM
3C3Z-6006-BARM
4C4Z-6006-BRM
4C4Z-6006-CRM
4C3Z-6006-AARM
4C3Z-6006-BARM
4C2Z-6006-EARM
5C2Z-6006-AARM
5C3Z-6006-AARM
5C3Z-6006-BARM
5C3Z-6006-EARM
5C4Z-6006-CRM
5C4Z-6006-DRM
5C4Z-6006-EARM
5C4Z-6006-FARM
6.0L (Complete)
3C3Z-6007-AARM
3C3Z-6007-BARM
4C2Z-6007-AARM
4C3Z-6007-AARM
4C3Z-6007-BARM
4C4Z-6007-ARM
4C4Z-6007-ANRM
5C2Z-6007-AARM
5C2Z-6007-BARM
5C3Z-6007-AARM
5C3Z-6007-BARM
5C3Z-6007-CARM
5C3Z-6007-DARM
5C3Z-6007-EARM
5C3Z-6007-FARM
5C4Z-6007-GRM
5C4Z-6007-HRM
5C4Z-6007-JARM
5C4Z-6007-KARM
Old Oct 9, 2007 | 10:53 AM
SpartanDieselTech
Former Vendor
Maybe they are bowed up like a canoe, just like every other set of 6.0 International heads I've worked on in the past 6 months....
Old Oct 9, 2007 | 07:02 PM
gb'sfx4's Avatar
gb'sfx4
on mine the valve guides were too tight on cyl. #7 causing the valves to sieze up when it got hot , then bent pushrod , broken rocker arm , & other bits & pieces
Old Jun 22, 2008 | 07:07 AM
poopdk's Avatar
poopdk
Try Alabama Cylinder Head
here the link index
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
Mar 9, 2016 12:40 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Aug 22, 2012 11:39 PM
