Hulk
Old Oct 5, 2007 | 08:39 PM
dwbfordman's Avatar
dwbfordman
Hulk
I have a 77 Ford F-150 Shortbox 351 m automatic lockouts limited slip i was wonderin i just had the carberator rebuilt on it 2 barrel holley and sometimes it runs at 1100 at idle and it dont die thenn sometimes at 600 its weird but when i put him in drive and come to a stop sign it act like its dying and then sometimes it will just idle whats the problem and what kind of gears came in that year
Old Oct 5, 2007 | 08:46 PM
masterbeavis's Avatar
masterbeavis
take it back to the person who did it and make them fix it. If they did the carb, and you installed it, what did you do when you changed out the carb. If you installed it, did you adjust it? Do you know how to adjust it? Did you read up on adjusting it? Do you own a haynes or a chilton manual?
Old Oct 5, 2007 | 08:59 PM
75F350's Avatar
75F350
Sounds like a simple vacuum leak.
Old Oct 6, 2007 | 12:44 PM
dwbfordman's Avatar
dwbfordman
yea i took it off and brought it in then put everthing back on like i took it off c it did the same thing before i took it in i own a haynes manual will that tell me where vaccum lines go
Old Oct 6, 2007 | 12:50 PM
Mil1ion's Avatar
Mil1ion
Do you have a throttle solenoid on that carb ?
Old Oct 6, 2007 | 12:51 PM
dwbfordman's Avatar
dwbfordman
i think so
Old Oct 6, 2007 | 01:10 PM
masterbeavis
Originally Posted by dwbfordman
yea i took it off and brought it in. Then put everthing back on like i took it off. It did the same thing before i took it in. I own a haynes manual will that tell me where vaccum lines go?
I added some periods so I could understand what you were typing.
No, a Haynes will not tell you where your vacuum lines go. You should have a sticker on the hood that shows where everything goes. (assuming you did not throw away all of your emissions equipment) When you replaced your carburetor, did you bother to change the EGR spacer to intake gasket, carb to spacer gasket, and check your EGR valve for vacuum leaks?
You need to:
1. Verify all of your vacuum lines are hooked up correctly.
2. Use an unlit propane torch, or carb cleaner to check for vacuum leaks. Check all hoses, and around the carb.
3. Check and adjust your timing
4. Re-adjust your carb. Gently screw in both needle and seat screws under the bowl, and back off 1 1/2 turns. Buy, borrow or aquire a vacuum guage. Turn the screws out a little bit, listen to the motor start to run better and watch as the gauge should read higher. When it stops moving higher, move to the other side. using this (incomplete) method should get your carb close to where it needs to be. Your exhaust should not stink or make your eyes burn. Do a search on carb adjustment if you want to get it spot on.
