trans fluid ?
Old Oct 5, 2007 | 12:49 PM
lasthighboy's Avatar
lasthighboy
trans fluid ?
i'm rebuilding a c6 for a 75 or 76 4x4. what fluid should i use in it? the whole system will be clean. flushed torque converter, etc. what is the difference between type F and mercon III? thanks
Old Oct 5, 2007 | 01:15 PM
rclarke's Avatar
rclarke
The fluid relates to the friction material used in the overhaul. Which clutch plates used in the overhaul would determine which oil to use. I would try to use late model plates and use mercon/dexron for the fluid.
Old Oct 5, 2007 | 01:19 PM
lasthighboy
thanks. i dont know what friction material was used. the kit is from napa for a 68 and up c6(read on packaging)
