How much oil?
Old Oct 4, 2007 | 04:29 PM
dakotajeep's Avatar
dakotajeep
How much oil?
How much oil do I need to change the oil in my 1994 F350 7.3 NA? I think its between 12-14 but I have no idea...help!!!
Old Oct 4, 2007 | 04:35 PM
gumboluvr's Avatar
gumboluvr
I use a two and a half gallons with the standard filter. right at two and three quarters since I started using the powersmoke filter.
Old Oct 4, 2007 | 05:16 PM
brownieboy525's Avatar
brownieboy525
stock filter is 10qts
powerstroke filter is 11qrts
Old Oct 4, 2007 | 06:53 PM
dakotajeep's Avatar
dakotajeep
Thanks...I changed it and it took 11qts...I wanted to get the Mobil 1 filter but they didnt have it and I am impatient to say the least!!!
One quart of the 11 was Marvel Mystery oil (MMO) that my farmboy buddy said they use in their diesels and he uses in his diesel Tornado!!!
Have any experience will MMO?
Old Oct 4, 2007 | 08:55 PM
PLC7.3's Avatar
PLC7.3
Used MMO in my GW motorcycle, but put it in the fuel......... some members on a few diesel forums I visit use it as IP lube in the fuel.
Just a heads up .......
DieselDon
Oil consumption, and the proper checking of the oil levels in Ford diesels comes up periodically. Ford dipsticks are calibrated for hot oil. The 10 quarts in the IDI engines expand about 1/2 to 3/4 of a quart as the oil heats up, and contracts the same amout after cooling. If you check the oil first thing in the morning ( which I grew up doing ) the engines will all indicate oils level below full, but when checked hot, will ( after a 10 minute drain time ) the oil level is usually at full. If you are checking the oil cold, and keeping the level at full, you are actually over filling the engine which will burn of the extra rapidly.
Suggestion: Check oil hot after 10 minute drain time.
Don't add until level reaches add line ( 2 quarts ).
In my days at Ford this often cured, or at least improved, the apparent oil consumption complaints.
Old Oct 4, 2007 | 09:21 PM
dakotajeep's Avatar
dakotajeep
I am going to put it in my fuel too...I just on a whim decided to use it in the crankcase...
Thanks for the other info too!!!
Old Oct 4, 2007 | 10:15 PM
ford trans tech's Avatar
ford trans tech
ATF has the same qualities
Old Oct 5, 2007 | 09:46 AM
ELBEE 1's Avatar
ELBEE 1
PLC is right, less oil consumption at 2 qts. low. Crank can whip oil and ruin it. Thats why the dipp stick says "DO not over fill".
Old Oct 5, 2007 | 05:03 PM
gumboluvr's Avatar
gumboluvr
So PLC, sounds like I should be putting 8 or 9 quarts in my truck. 10 or 11 brings it right to the full line when cold (10 with IDI filter 11 with powersmoke). I never knew this, but I also never (well almost never) use any oil.
Old Oct 5, 2007 | 07:14 PM
fuzzy1626's Avatar
fuzzy1626
When I went to a PowerStroke filter I put in 11 qts. When I check it cold it's right on the the full line. Hot it's almost a half inch over. Mine doesn't use any because it's been that way for 3,000 miles. Next change I'll use a little less.
Bordermen
20
Sep 28, 2019 03:48 PM
billb2000
Flathead V8 & Flathead 6
May 7, 2012 06:26 PM
itsjustagreat1
Mar 5, 2009 08:24 AM
MJW
Mar 15, 2004 03:05 PM
bl55army
Oct 15, 2003 09:56 AM
