abs light 99 expo 4wd e/b
Old Oct 4, 2007 | 02:13 PM
bliomin's Avatar
bliomin
Can anyone help ? abs light came on . Does that mean that you need new brake pads ? Brakes seem to work fine right now .
Old Oct 4, 2007 | 07:33 PM
vjstangelo's Avatar
vjstangelo
Possible Fix
I recall having a similar problem with my '99. The light would come on shortly after starting the vehicle and stay on. I believe that when the light comes on the computer has turned-off the ABS due to a sensor problem. To fix mine, I had to replace an ABS sensor located on top of the rear axle housing. The part was available from Ford for under $100. Search the forum and you should find detailed instructions on the fix. I think it was just one bolt and pull off, unplug, and put in the new. No problems since.
Old Oct 5, 2007 | 09:11 AM
c_hohensee's Avatar
c_hohensee
The first place to go when you have a ABS warning light coming on is the rear sensor as was previously posted. I have bought them at an auto parts store for about $20 and they have lasted well.
