Those hand powered drills where you turn the crank are good for a lot of situations, They are excellent for tight work where if you go too far you risk damaging something behind what you are drilling. If you are on the trail you don't have to worry about the battery dying. Sometimes it seems to go through
materials faster than a powered drill. You will not wear out as many drill bits since it is almost impossible to overspeed the bit!! It has it's place in every tool box as well as a corded drill and a cordless drill.
