I recently had a performance exhaust put on which some of you already know. The issue is I just had to replace one of the O2 sensors and the other went bad yesterday while I was pulling out a stump.
I was talking to my niebor that was saying that I will go thru the O2 sensors every few thousand miles.
To help clarify my exhaust it has no CAT a dynomax single in dual out performance muffler and the two pipes with 12in crome tips coming out in front of the passenger side rear wheel.
If this is true is there a way that I can help remedy this O2 sensor consumption?
i'm not quite sure but i think since you removed the cat the o2 sensor does not get up to temp and that is the reason for the short life of it.
ps is it a v10?
