Well, it's clutch time....
Old Oct 3, 2007 | 10:32 PM
fellro86's Avatar
fellro86
I unfortunately don't know the history on my 86 enough to know for sure if it had a new one when they put the motor in, but 30000 miles after I got the truck, it has used it up either way. Suggestions for where to get one that can handle heavy hauling?
Old Oct 3, 2007 | 10:56 PM
symonds86's Avatar
symonds86
my buddy got a solid flywheel conversion kit from autozone and it is a very heavy clutch much bigger than the one we took out and ran him about 700$
Old Oct 3, 2007 | 11:02 PM
xjoedirt55x's Avatar
xjoedirt55x
just don't go cheap and make sure to have the flywheel machined
Old Oct 3, 2007 | 11:18 PM
catfish101's Avatar
catfish101
That truck should have a solid flywheel in it now. You can find 12 inch clutches just about everywhere. I have baught several of them.
Old Oct 4, 2007 | 06:03 AM
fellro86's Avatar
fellro86
Yes, it's solid, has the 4 speed. It's the 86 in my sig.This will be the first hard job I've had to do in the 3 years I have had the truck, worst before has been the alternator... I always get the flywheel machined with a new clutch, I just need a new disc and pressure plate.
Old Oct 4, 2007 | 07:49 AM
mistakenID's Avatar
mistakenID
I wonder how a Center Force clutch would do with these engines. I have never used one.
Has anyone put a Center Force in anything that can give an opinion??
Old Oct 4, 2007 | 08:51 AM
ELBEE 1's Avatar
ELBEE 1
The older solid fly-wheel 12" style, is still the best deal all around. We even replace later models with that set-up. Buff and anti-sease the in-put shaft, and don't forget to replace the main seal.
Old Oct 4, 2007 | 09:28 AM
tjc transport's Avatar
tjc transport
i ain't rite
i had a centerforce dual friction in my 88 for 80k miles before i put the auto trans in it. never had a problem with it, and it looked like new when pulled. as a matter of fact, the guy that bought the ZF bought the clutch also, and has put another 100k on it so far.
Old Oct 4, 2007 | 10:57 AM
fellro86's Avatar
fellro86
Yep, rear main is getting changed, it is leaking already even though the motor is supposed to only have 5000 miles more than I have on it. They do make a sleeve
kit for these don't they?
So what kind of money would I be looking at with a Centerforce?
JackEmUp696
Aftermarket Products
Jan 1, 2013 08:17 PM
86f15035s
Minnesota Chapter
Mar 10, 2011 02:00 PM
willj86
Sep 25, 2005 05:46 PM
Double T Dave
Dec 1, 2004 03:59 PM
