Van Engine Swap
Old Oct 3, 2007 | 10:04 PM
pettit5's Avatar
pettit5
Question Van Engine Swap
Hi!
I have a 1993 E-150 conversion van with a 5.0 and an overdrive tranny (VIN "N"). The engine is getting tired and I'm looking at putting a 5.8 out of a 1990 Bronco into it. Will this bolt up to my existing trans? Will I need to pull the ECU from the Bronco too? The 5.8 is a rebuilt with only a few thousand miles on it before my Nephew rolled the Bronco on the ice last winter. Any help would be appreciated.
Thanks,
Scott
Old Oct 4, 2007 | 10:30 AM
Conanski's Avatar
Conanski
The motor will boltup fine, the computer could be an issue however, it depends upon the tranny in the van. Does the bronco have the same tranny as the van? My guess would be the Bronco has a C6(non computer controlled) while your van has an E4OD which is computer controlled. If so you'll need an ECU for the 5.8/E4OD combo.
Tmac6696
1978 - 1996 Big Bronco
Oct 30, 2015 11:48 AM
budman241
Sep 29, 2015 11:43 AM
quickieR
Sep 19, 2015 08:21 PM
shryock10
Aug 13, 2015 10:41 AM
mauicruza
Mar 14, 2005 01:11 AM
