Exhaust ????
Old Oct 12, 2007 | 08:27 AM
MBRP TECH 3's Avatar
MBRP TECH 3
Sponsor
Thumbs up Mbrp
Originally Posted by Michaeltharris
I'm looking at a 4"MBRP Turbo back if I use the cat delete pipe that will also make it a little louder right. I want something a little louder but I believe if I take myffler out its going to be a little to much.
Hi guys MBRP makes two systems a turbo back system that keeps the stock cat & a an off road system that deletes the cat , this system will be louder as well you can not put the cat back in this system.
the turbo back system is the same as the cat back system for sound untill you delete the cat with a delete pipe .
You can get this from any of the supporting venders
