360 exhaust&oiling
Old Dec 21, 2001 | 04:21 PM
6t6merc's Avatar
6t6merc
360 exhaust&oiling
Old Dec 21, 2001 | 06:13 PM
ford fanatic's Avatar
ford fanatic
Post 360 exhaust&oiling
I have heard 360's have very restrictive exhaust and oiling systems. Is there anything I can do to free up the exhaust other than installing bigger exhaust valves? What size valves should I use? This is a resto truck so no headers I want it to look stock.
Also I heard that the oiling system is not efficient enough to do much pulling I have a boat and a drag car that I pull so what can I do to help me there?
72 Ranger XLT
360
C6
Old Dec 21, 2001 | 09:04 PM
dinosaurfan's Avatar
dinosaurfan
360 exhaust&oiling
Adam, the exhaust can be helped with an upgrade to the 1.65 CJ428 valve, and some bowl blending and grind the lump out of the roof of the exhaust port. But without headers you are still going to be strangling the poor thing. For the oil, there are several passages that are mis-aligned or too small. To do a proper fix, the engine has to come out of the truck. After the fixing, a windage tray and bigger oil pump will put you on your way to indestructability. Do you know what to do on the oiling or should we walk you through it ? DF
Old Dec 26, 2001 | 12:00 AM
ford fanatic
I guess you should walk me through it. I know headers free up the exhaust alot but like I said, resto truck, has to look stock. The engine is not in it at the moment.
