Steering Play
Old Oct 3, 2007 | 07:55 AM
387designs's Avatar
387designs
Steering Play
The truck (85 F150 I6) tends to float a great amount, so i have my brother sit in the truck and wiglee the steering wheel, the play seemed to be in the ball joint where the tie rod connects to the pitman arm. What parts do I need and can I get them at napa? I assume I need to replace the ball joint, which probably means I need a special puller. It has a new steering box and power steering pump.
Old Oct 3, 2007 | 01:13 PM
blue beast's Avatar
blue beast
If you can afford it just replace all of them, Make sure the new ones have zerk fittings and keep them greased up. You will need a pickle fork and sledge to remove them!!
Gwt a piece of cardboard and mark the length of each one from the center of the end to center of the other end. You want to keep the lengths as close as possible then take it and get a alignment!!
Old Oct 4, 2007 | 11:19 AM
387designs's Avatar
387designs
That was a "my bad" I did a search and found everything I need to know, but now I can't decide which ball joints to buy, since the moog are considered to stiff and the OEM don't last, I was considering the summit racing ball joints, good idea, bad idea? Should I replace the U-joints at the same time (they dont seem to be bad)?
Old Oct 5, 2007 | 12:59 PM
cleeE150's Avatar
cleeE150
what ever you use keep them lubed from day one, should last long time, have 400,000 miles on mine from factory, still working great, maybe go with ford parts (factory),?
mykdee
Dec 23, 2011 05:29 AM
scameron
Jul 4, 2011 08:23 PM
AndeyHall
Feb 3, 2011 07:15 PM
X-70STANG-F150
Sep 5, 2008 06:27 PM
