97 7.3 with transmishion problems help?
Old Oct 2, 2007 | 08:31 PM
6.0 heavy loader's Avatar
6.0 heavy loader
When my truck goes into gear nothing goes wrong when i try to drive it lags then kicks into drive after the rpms hit about 1500 any ideas?
Old Oct 2, 2007 | 08:52 PM
Neal 97 250's Avatar
Neal 97 250
Is the fluid fresh? I am not the pro at tjhis so just check the basics and the pros will be here soon.
Explain a little better though. When it goes into gear nothing wrong ( in first gear only?). When it lags do you mean between shifts 1-2 or 2-3 or 3-4 or all? What do you mean , when it shifts into drinve, Do you mean 3rd or 4th? Answer some of these the best you can and the true auto pros will be here soon.
BTW Welcome to FTE. You will learn much here. Just hang on and post often any question or observation. We encourage ALL questions and I promise they will be answered.
Old Oct 3, 2007 | 06:51 AM
Cuda_jim's Avatar
Cuda_jim
If you have any programmers or mods you should return the truck to stock.
Have it scanned for codes even if the CEL is off. No scanner? Most tranny shops will scan it for free. They want your biz. They must drive the truck to scan it correctly, go with them and watch the scanner.
Is the OD lite in the shifter handle flashing?
Do the easy things first. Check fluid level and condition. New filter and fluid is always a good thing. Take a look at all the connectors on the trans and check them for loose, corroded, bent or burnt pins and sockets in the connectors.
Old Oct 3, 2007 | 11:16 PM
6.0 heavy loader
It only does this to first gear it does not slam into first it slowley goes into after it reaches 1500 or so rpms
