smoke on start up
Old Oct 2, 2007 | 05:42 PM
Fordman400 4x4's Avatar
Fordman400 4x4
smoke on start up
1978 400. the truck has 134000 on it but i dont know if the engine is the original or been rebuilt or anything about it. all i know is that it puffs a little blue smoke on start up. any ideas?
Old Oct 2, 2007 | 10:19 PM
hollenjoe's Avatar
hollenjoe
black smoke = gas, engine running rich
blue smoke = oil burning ( bad thing : maybe bad seats, rings, or even cylinder walls)
white smoke = water burning
its sometimes dificult to determine wether its is black or blue smoke you are seeing
Old Oct 3, 2007 | 05:29 PM
trinogt's Avatar
trinogt
Smoke on startup is usually blue or black.
Blue means that you likely have some valve stem seals that are dried out and cracked. Go get some new ones, and invest in a valve spring compressor. They are very affordable now for the backyard mechanic. Good time to replace those valve cover gaskets that may be seeping by now too.
Oh, and in case it hasn't been done already; Welcome to FTE!
Old Oct 4, 2007 | 01:27 PM
FXForistell's Avatar
FXForistell
+1 on the valve seals. Especially if the smoke dissipates greatly after she warms up. Not a big deal or hard fix, really.
Old Oct 4, 2007 | 04:42 PM
Fordman400 4x4
sweet i was leaning toward valve seals anyways. i guess ill get a set and VC gaskets while i have them off
Old Oct 4, 2007 | 04:53 PM
53fatfndr's Avatar
53fatfndr
The 400 in my '79 has been puffing blue on startup for the last 10 years...it has been getting worse though. I'm with the others, it is probably the valve seals.
Old Oct 4, 2007 | 06:18 PM
Fordman400 4x4
just ordered the valve seals! they will be here in the morning and in my engine on saturday morning. purchased valve cover gaskets also
Old Oct 4, 2007 | 07:11 PM
jdsdidit's Avatar
jdsdidit
Wish I had done mine sooner. Found a piece of valve seal in my oil pump which locked it up and sheared a tooth off the cam(some idiot had put a nail through the distributer gear before I bought it). Good news is it gave me a reason to put a new motor in!
Old Oct 5, 2007 | 12:25 PM
trinogt's Avatar
trinogt
Do you have a spring compressor already?
I bought myself the kind that has two jaws top and two bottom and a handle to crank that compresses the spring. This works on a greater variety of engines, including foreign cars with overhead cam.
Old Oct 7, 2007 | 07:37 PM
Fordman400 4x4
nah i dont have one. ill have to borrow one
1995F250351
Jul 6, 2015 02:46 AM
2thetop
Nov 14, 2014 09:10 PM
npccpartsman
Oct 27, 2013 11:58 AM
capscrap
Dec 9, 2006 09:07 PM
Wyobuilder
Aug 18, 2003 03:46 AM
