hi guys and gals, need some help with casting numbers, believed to be a 429 out of a 69 t-bird, verticlly it reads C8VE F YES F the second line in the F seems to carry beyond the vertical line NOT a or e. under that is backward OR MIRROW IMAGE numbers 064 AND under that is 1?
ON the head under valve between 3rd and 4th valve is number C8VE E Meaning 68 thunder jet head 385 series is this correct?
Need some help with this one, want to order new rings/bearings etc for a rebuild any help would be grateful thxs.
You will want to try out out tech forums. Click on the Forums tab at the upper left and scroll over the list. Try this one out: https://www.ford-trucks.com/forums/forum53/ There are other boards that may be able to help so check them out.
