need help!
Old Apr 14, 2007 | 06:45 PM
32acres's Avatar
32acres
need help!
hello everyone, i've never been in a chat room before. so, not only do i need truck help, i am also new to this. my truck needs much, so i should be a chat room pro in no time.
Old Apr 14, 2007 | 08:13 PM
Ultramagdan's Avatar
Ultramagdan
Hello and Welcome!
I would recommend trying the tech forums. Click on the Forums tab at the upper left and browse over the boards. If it's for your 92 then you will want this one: https://www.ford-trucks.com/forums/forum28/ I also recommend the chapter for your surrounding states since it provides local information and support. Check it out and see if you like it: https://www.ford-trucks.com/forums/forum158/
Good Luck!
Old Apr 14, 2007 | 09:18 PM
32acres's Avatar
32acres
thanks
thanks for your help. it takes awhile to respond as i share computer with 4 others. i will take your advice. Rob
ohiooutlaw69
New Member Introductions
Apr 7, 2008 05:07 PM
1970 Ford Man
Mar 23, 2008 05:12 PM
bartmac
Oct 2, 2007 04:57 PM
catcherkp
Apr 19, 2007 06:47 AM
kparker77
Mar 9, 2007 09:40 PM
