Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
The gremlins strike...
Old Oct 2, 2007 | 12:01 AM
t_dickie's Avatar
t_dickie
So I was at the farm for a wedding this weekend, and the Sunday after I had some minor truck work to do (read oil change) So I changed that and gave her the ol' once over. I'd been hearing a noise for a couple days prior, and when I started I thought I should check it out, but, alas, I forgot. No big deal I thought, I can check them when I'm back in the city. So today, I'm out checkin things out, saw it wasn't a brake issue, so moved onto the wheel bearings. Picked the left side up, and sure enough, its sloppy. ****, lets check the right side. Pick the right side up, and my whole freakin wheel is loose! Cept its not loose lug nuts, the studs are spinnin! So I went from what I thought was brake pads at worst, to havin an undrivable truck!
Old Oct 2, 2007 | 12:09 AM
Fomoko1's Avatar
Fomoko1
That`s on the 92 ranger or the 94 F150?
Hope it`s not major.
Old Oct 2, 2007 | 12:10 AM
t_dickie's Avatar
t_dickie
That's on the ranger, had to send the F-150 down the road a couple years ago.
Old Oct 2, 2007 | 07:19 AM
96sherm's Avatar
96sherm
thats not too sexy!! hope ya get her fixed up good and it don't cost your leg...
Old Oct 2, 2007 | 08:04 AM
preppypyro's Avatar
preppypyro
Well man at least you found it now, before the wheel actually fell off on you.
Old Oct 2, 2007 | 01:26 PM
t_dickie's Avatar
t_dickie
Now I need some advice. I need to get the wheel off, but with the studs spinning I'm not quite sure how to do it. Keep in mind that I am way understocked when it comes to tools here. All I have is a good, but basic, set of hand tools (SAE & Metric wrenches, 1/4", 3/8", 1/2" SAE & Metric sockets) and no air. I tried positioning the wheel so it would create more pressure on the studs, but they still spun.
Old Oct 2, 2007 | 06:49 PM
96sherm's Avatar
96sherm
is there any way to get at the back of the stud?? maybe grind it off, or somehow pinch it to stop from spinning. worse comes to worse, a bit of weld on them it you have access to a welder...just some thoughts
Old Oct 2, 2007 | 08:59 PM
Snowking's Avatar
Snowking
That is exactl what happen to my 93 F150, but the noise I had stared 3 blocks before my front driver wheel partially fell off.
Old Oct 2, 2007 | 09:37 PM
Dustin1690's Avatar
Dustin1690
Wow scary stuff....
Old Oct 2, 2007 | 10:03 PM
preppypyro's Avatar
preppypyro
Sounds like a cutting torch might be in order.
Fomoko1's Avatar
Fomoko1
Front or back wheel?
If it`s the front wheel can you take the hub off and then tackle the studs from behind?
Or am I missing something here?
Old Oct 2, 2007 | 10:19 PM
Corner Gas's Avatar
Corner Gas
Like Morris said, just take the front hub off and work from the back.
Old Oct 2, 2007 | 11:20 PM
t_dickie's Avatar
t_dickie
Cutting torch is no good, its an aluminum wheel.
Can't weld it, as I can't get to the backside of....... anything.
Can't take the hub off - the rotor and hub are one piece. In order to do that I have to take the wheel bearings out, which will eventually happen, once I get the wheel off. The only way I could take it off would to be to take right axle out, which considering its a TBB......
But thanks for all the ideas guys, got any more?
Old Oct 2, 2007 | 11:33 PM
Fomoko1's Avatar
Fomoko1
I`ve never been that clsoe to a 4X4 so I can`t help.
Old Oct 2, 2007 | 11:45 PM
51dueller's Avatar
51dueller
Your really in a pickle. I would say to remove the rotor and weld the studs so you could remove the wheel but the axle hubs are only removable with the wheels off. Another way would be to remove the caliper to weld the studs but you can't remove the caliper as it would hit the wheel.
The only way I could see it would be to destroy the dust cover and then weld the studs. Then remove the lug nuts with an impact.
