turbo upgrade?
Old Oct 1, 2007 | 07:36 PM
JRAYMOND's Avatar
JRAYMOND
Smile turbo upgrade?
i've been looking for more power in my early 99 f250. i currently running a volant cold air intake , 4'' turbo back magnaflow exhaust , and dp tuner adjustable chip. the truck works great but always looking for more. the only turbo upgrade i can find for my early 99 is from hypermax. they say if i go with their turbo and stage 1 injectors i'll be at 425bhp and over 900ft lbs. anyone running this set up and if so does it work and worth the money? thanks for any info.
Old Oct 1, 2007 | 07:44 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
If i were you, i'd go with stage two injectors, and a Beans Diesel Performance Dominator 66 turbo for your early 99.
Old Oct 1, 2007 | 08:08 PM
JRAYMOND's Avatar
JRAYMOND
thanks for the info. i've never heard of that brand turbo before. what's the difference and why is it better?
Old Oct 1, 2007 | 08:16 PM
justblowin'smoke's Avatar
justblowin'smoke
go to dieselsite.com they sell a kit to upgrade to the late model set up and u can run what ever turbo u want for the 7.3
Old Oct 1, 2007 | 08:31 PM
JRAYMOND's Avatar
JRAYMOND
Smile
what turbo is the best to go with? only want to buy one and not regret which one i got-thanks
Old Oct 1, 2007 | 08:38 PM
SVLERF250PWRSTRKE's Avatar
SVLERF250PWRSTRKE
I would go with a good Holset turbo with a AR close to 1, the stock garret turbo is junk for high performance. Stock is close to 2 psi of exhaust for 1 psi of boost. Good for turbo response and stock settings.
Old Oct 1, 2007 | 08:48 PM
justblowin'smoke
me personally i'd go w/ a ball bearing turbo either the ats or the garret with a better ported compressor housing both have an AR of 1 the ats is 1800 from diesel performance specialist and the garrat is 1500 from dieselsite and another hundred for their ported compressor housing
Old Oct 1, 2007 | 09:33 PM
PowerstrokeJunkie
http://www.beansdieselperformance.com/99-03turbo.htm
The Dominator 66 is a direct bolt on turbo. You do not need to replace your pedistal and uppipes to run this turbo.The high performance turbo upgrade will flow 1050 CFM. That is a 30% air flow increase of stock. This turbo has a 1 Year replacement warranty. That is almost 100CFM more than the Hypermax H2E turbo at less than half the price and installation time. Maximum recommended pressure is 40PSI. Core required. $1325.
You can't beat the cost! The stock replacement turbonetics, you can't get for that much, and this one is much bigger! it's a 66mm turbo, comparable to a Hypermax H2E but the nice thing is that it's a direct bolt on for the early 99 guys. A dude on PowerstrokeNation made 471 hp with this turbo and B code injectors. (much larger than you want)
Old Oct 5, 2007 | 08:37 PM
JRAYMOND's Avatar
JRAYMOND
Smile
thanks guys. i've ordered a dom 66 and stage 2 injectors from beans diesel. they say with my current mods and the new turbo and injectors i'll be somewhere near 400 rwhp. should get them sometime next week. once i install them i'll let you guys know i made out and how i like my new step up.thanks john
