question?
Old Oct 1, 2007 | 05:06 PM
sckootter578's Avatar
sckootter578
Lightbulb question?
ok my 1981 f-150 straight 6 has a miss while idling and smells real rich out the exhaust what could I check ?
Old Oct 1, 2007 | 05:22 PM
RickDill1's Avatar
RickDill1
If it has a oxygen sensor I would replace it $15. I would also get some Berrymans and spray that carb.
Old Oct 1, 2007 | 06:29 PM
Franklin2's Avatar
Franklin2
I would rebuild the carb.
Old Oct 1, 2007 | 07:09 PM
srercrcr's Avatar
srercrcr
No O2 sensor in an 81.....hadn't even been thought of yet.
Seems to be common the EGR valve is clogged up/inoperative.
When was the last major tuneup?
Old Oct 2, 2007 | 05:59 PM
sckootter578
I dont kow um just boght the truck it runs fine exells good through the gears just at idle it will idle smooth then all of a sudden it will miss like a quick hick up .
Old Oct 2, 2007 | 06:32 PM
srercrcr's Avatar
srercrcr
Tough one being erratic. I'm gonna guess the timing is off just a tad, whereby once in a while it hiccups.
Old Oct 2, 2007 | 06:35 PM
srercrcr's Avatar
srercrcr
Could very well be a weak spot in the primary circuit...from dizzy to plugs.
Does it do it more when it's damp out?
Wipe the plug wires and dizzy cap off....spark may be finding a better route to travel.
Find a totally dark location and observe the engine idling to see if you see an errant spark.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
