Sponsored by: Real Truck
vibration when starting from a stop
Old Oct 1, 2007 | 07:44 PM
earl964's Avatar
earl964
I have a 99 F-350 4x4 that seems to shudder when starting from a stop any ideas ?
Old Oct 1, 2007 | 08:46 PM
redford's Avatar
redford
FTE Leadership Emeritus
Is the truck lifted?
Old Oct 1, 2007 | 08:49 PM
SUPERDUTY_untouchabl's Avatar
Give it some gas when letting off the clutch.
Old Oct 1, 2007 | 09:15 PM
pete98cobra's Avatar
pete98cobra
Need more info on your truck.
Have you checked u-joints for any play, check carrier bearing,and slip shaft on your drive shaft.
Old Oct 1, 2007 | 11:50 PM
kbeefy's Avatar
kbeefy
ujoints or clutch.
If lifted you need to shim the rear axle down.
Old Oct 2, 2007 | 06:42 AM
earl964's Avatar
earl964
it is an automatic with no lift
