Aftermarket Products
Sponsored by: Worksport
Line-X UnderHood
Old Sep 30, 2007 | 04:15 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
Line-X UnderHood
Has anyone had Line-X (or equiv) sprayed under their hood? Just had a new hood installed (warranty) and was wondering about using Line-X instead of buying a felt liner.
Old Sep 30, 2007 | 05:42 PM
brmpipes's Avatar
brmpipes
im sure this would work,other then the weight that this coating would add to the hood.its quite heavy apperently.Im sure you would spray it on fairly thin but still an issue.
Old Oct 1, 2007 | 10:25 AM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
Good thought...I'll have to ask my installer.
Old Oct 1, 2007 | 12:55 PM
TruckDaddy's Avatar
TruckDaddy
LINE-X weighs .7 pounds per square foot at 1/8" thickness. For your hood, I think 1/16" is plenty. Temperature tolerance is about 220 degrees.
Old Oct 1, 2007 | 04:14 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
Do you think that the extra weight will make stop the hood from staying open?
Old Oct 1, 2007 | 07:04 PM
brmpipes's Avatar
brmpipes
i dont think i would put my head under it in a wind storm lol.
Old Oct 2, 2007 | 07:28 AM
tomtoc's Avatar
tomtoc
doing the math, especially at 1/16th i'm coming up with it adding ~9 pounds. doesn't sound like that much to me.
Old Oct 2, 2007 | 03:11 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
Stopping over to the Line-X dealer here in Glen Burnie tomorrow...will let you know what he said.
Old Oct 2, 2007 | 09:10 PM
F350-6's Avatar
F350-6
I'd start by hanging weights on the hood and see what point the hood no longer stays open. I know spreading the weight over the entire hood will change the critical weight, but this will give you an idea. Any winds in a borderline situation will likely close the hood for you. I know if you remove one of the little shocks that supports the hood it won't even attempt to stay up.
It is an interesting idea though. If you decide to do it make sure you pay attention to the noise difference. If it works out maybe we can name a mod after you.
Old Oct 3, 2007 | 01:01 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
NOT doing the LineX!! Dealer doesn't advise it because of high underhood tempertures. Line-X starts melting at (about) 300 degrees. I have the 6.0 turbo. He read temp with it from idle to 2K RPM...my gauge read 600*, he read close to 300 with hood OPEN! I don't want black crap dripping on the engine so I declined. He said he'd do it if I wanted. About $200.00...I said no thanks.
I stopped by the Lincoln dealer and ordered the Lincoln Mark LT underhood insulation. It LOOKS to be the same hood as the 250 (or dang close). It doesn't get in for about a week. After I get it installed, I'll let ya know hope it goes. Price was $80 something WITH all the mounting hardware and Maryland tax. I think he said the insulation was 65. There's 14 plastic push pins that look to hold it on. Looking at my hood, it looks like all the holes are already drilled for it.
Old Oct 12, 2007 | 03:10 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
Picked up and installed the insulation today. NOT an exact fit, but very close. Had to drill a few holes for the push pins to hold it up, but it only took less than an hour to look at, mark, drill and install. Hardest part was getting the hood lamp back on.
Old Nov 14, 2007 | 10:36 AM
Ryan50hrl's Avatar
Ryan50hrl
did it quiet it down enough to justify the purchase?
Old Nov 14, 2007 | 12:51 PM
Beerstalker's Avatar
Beerstalker
Look around in the Super Duty forum. There are quite a few threads on this. The guys have used the insulation from the 99-04 trucks, and have posted part numbers for it and the clips to hold it in place.
Old Nov 16, 2007 | 03:19 PM
Ryan50hrl's Avatar
Ryan50hrl
hum....i'm quite happy with my 07 f-150 noise level....but quiter is always better....for 85 bucks i might have to go check this out
Old Nov 17, 2007 | 12:58 PM
topgo's Avatar
topgo
Hi; I must be living on a different Planet. I want to Buy a Fuel flow & milage sensor ect Display. 1995 F350 7.5 1 ton. The units used to be hanging on trees! Even JC Pennys and Whitney had them until
FI
