Highway Driving
The truck is geared pretty low. Pathetic gas mileage when going 55 mph. Well, I'm not asking what I can do to increase my MPG, as I knew that I would have to deal with that when I got the truck. I'm just wondering... can this truck go down the interstate at a sustained 70 - 80mph without causing any damage? I have no clue what RPM I would be riding at, but maybe someone else can clue me in here. I can't remember what size tires are on it at the moment, but they seem to look a little taller than on most trucks like this I see. Maybe it's just me, but either way, who else has a truck with this gearing and takes it down the intersate at 70+mph.
I might be getting a job where I will have to ride 45 minutes on I-81 where the speedlimit is 70mph. I have a motorcycle... but I'm not riding that in the winter time. Sure, I can get a little beater car... but until then, what do you think about this truck at those speeds for 30 - 45 minutes?
Also, for a truck with this gearing, what kind of oil would you recommend? Is 10w-30 thick enough, or do I need to move up to a 40 weight? I have good oil pressure, but I don't know what oil is in it. I haven't had it for all that long. Has a Kendall sticker in the window, but doesn't say what weight was used. I'm an oil fanatic and love to change my on oil, ensuring the job is done properly. And I like to know I have a good weight matched up for the engine, lol. What weight oil do you guys use?
Ideal for this 302 is usually 2500 rpm (or less), but they can cruise over 3000 if needed, they have a short stroke for their size, and can easly handle those RPMs.
I run 10w30 oil and always have, don't know what advantages there would be in switching to anything else.
You might consider trying to cruise at 60 mph instead, fuel economy will be better, it you can stand getting past by everyone (not easy i realize).
This truck is geared pretty low in the 1st - 3rd (1st, especially, duh... I never use it), and 4th doesn't seem ALL too bad, but you can tell you are where the 'power is' when cruising @ 55mph, so I was just curious about what RPM I might be pushing at 70mph. Thanks, again. And if anyone else has any input, please go ahead and share.
I think you would be fine cruising at 70. As long as you keep up on the fluids and pay attention to any odd noises or leaks, your truck is fine. Also 10-30 is a good choice thats what I run, but you might consider a synthetic if your looking for a little more mialeage and protection.
It very well may be made at the same refinery...I know there's no refinery in Bentonville, Arkansas.
I personally use synthetic in the vehicles that will run it without buring it or leaking it and use Penzoil in the others. I couldn't care less and may switch brands tomorrow as long as it isn't Castrol GTX.
FWIW - One of the blown motors was a Triumph straight 6 that is supposed to be bullet proof. The other two were Chevy ( I know Boo Hiss) 3.5L that was also supposed to be a reliable motor.
My 86 F-150 truck runs Mobil one and only leaks one drop on initial shutdown from the rear main but won't leak on Pennz so I run the synthetic in it anyway putting up with the leak to get the added protection and milage. My Mercury 4.6L burns synthetic so it is on Pennz. Don't know why the newer car burns the syntetic and old truck doesn't but both motors are in great shape and on "normal oil" don't leak or burn a drop between changes. Just one of those things that make you go Hmmmmm.
PS - those Chevy 3.5L rn OK but they leak like strainers if you push them like a Ford. If you drive like a grandma I guess they do OK but they can't take any lead foot action or seals blow out left and right. I'll never own another Chevy!!! I changed every seal in those things at least 3-4 times. Go Ford!!
Good Luck,
Lee
I ask this because... and hear me out... on bobistheoilguy.com, Castrol GTX 10w-30 gives some of the BEST used oil analysis on that website. I won't bore you going into detail about bobistheoilguy, but either some of you will already know about it... and the others will go there (smart choice) and look at people's tests sent in on their oil in their cars.
Again, I'm not arguing that Castrol GTX is a good or bad oil. Some of you... it must have done you bad. As for me, in the last 5 years, it's all I have used. And... sad to say, but I used to run the absolute crap out of my cars and they never had any problems. Namely my 1991 Dodge Stealth R/T 3.0 V6 DOHC non-turbo (I had to others with twin turbos), but this non-turbo took such a bad beating, I feel bad for it now. It went from 120,000 miles to 190,000 miles, all from me. I swear it saw 7300RPM every day, multiple times. Castrol GTX only. Still has great oil pressure.
But, it could have done the same with ... Havoline, Valvoline, Quaker State, Pennzoil, etc.
BTW, I've got to ask, you guys that like Pennzoil and hate Castrol... are you in your upper 30's, lower 40's by any chance?
I asked for any objections and I got them. Again, I don't want to come off like I am arguing, becaues I'm not. I, too, want to find the Holy Grail of conventional oil. Be sure to check out bobistheoilguy.com.
