Wheel base OFF What to do
Old Sep 30, 2007 | 12:23 PM
RUSTY50F1's Avatar
RUSTY50F1
I marked the rear end on the 50f1 when I took it out. When I try to hang the jag irs the wheel base on the drivers side is 113 3/8. On the pass side it is 114 as it should be. I measured from different points on the frame. The rear is dead square. And the Jag Ifs is on the marks. Could it just be the front end out of alinement.
Old Sep 30, 2007 | 01:35 PM
Brian_B's Avatar
Brian_B
Could it be that it was off when you took it apart? This is a 50 something year old vehicle. Did you check?
As far as a fix...I have no clue. Just lots of measuring and find out what is off?
Old Sep 30, 2007 | 02:03 PM
RUSTY50F1's Avatar
RUSTY50F1
Thanks Brian I know my frame is out of square about a 1/4 of an inch I'm trying to square it up now. that might help some. I know they are made to flex. Could be some of it.
Old Sep 30, 2007 | 02:08 PM
Brian_B's Avatar
Brian_B
1/4" is not much at all. I bet most new frames are not much closer than that.
Is that overall (front to back)? Each section (between the crossmembers) could be out just a little with our ladder type frames. One one way and the next a little off the other way.
50+ years who knows what has been done to them and what sort of loads they have had on them.
I wish I was around to help. I used to straighten totalled cars. I never had a frame table, just a good tape measure and a home made frame machine (10 ton hydraulic ram). We never got them perfect, but that is what the 4 wheel alignment was for.
Old Sep 30, 2007 | 02:13 PM
tip49's Avatar
tip49
I too have slight misalignement of my rear axle, by 1/4" on driver side may or may not adjust the axle.
Tom
Old Sep 30, 2007 | 02:14 PM
RUSTY50F1's Avatar
RUSTY50F1
If I get the wheel base with in 3/8 of each other will that work. I don't want it to go down the road sideways or look funny.
Old Sep 30, 2007 | 02:20 PM
havi's Avatar
havi
I'll have the Roast Duck
have you measured it diagonally from front to back? that'll show if the frame has a diamond shape to it. I'd try for 1/4" if it was me.
Old Sep 30, 2007 | 03:22 PM
RUSTY50F1's Avatar
RUSTY50F1
Ok I know the tow in is off a little on the front. I put the rear right under the bump stops. measured the frame criss cross. It's great 1/16 out of square. At this time I have 113 7/8 on both sides. I'm going to mark the rear cross member and task weld it where it is. I think for some reason the front wheels are about a 1/2 inch back from original. Not sure why. A come along and a chain brought the frame back. I hope.
Old Sep 30, 2007 | 03:33 PM
Brian_B's Avatar
Brian_B
Are you at the correct wheel base for yours now?
Ours are 110", but should be 111". Some of the lowering springs actually move the front axle center forward to where it should be. LOL
Look at the front wheel/fender of the stock 53-56 and you will see what I mean.
Ford messed up?
Old Sep 30, 2007 | 05:21 PM
mechmagcn's Avatar
mechmagcn
[QUOTE=RUSTY50F1]Ok I know the tow in is off a little on the front.[QUOTE]
Rusty, are you trying to measure the wheelbase by using the center of the front hub? If so, if the front wheels are not exactly straight, you will be off by quite a bit. Try using a stationary point on the front suspension, like the grease fitting on the lower ball joint to measure from, this doesn't move when the wheels are turned, so it will always be in the same place.
Old Sep 30, 2007 | 10:01 PM
RUSTY50F1's Avatar
RUSTY50F1
Thanks mechmagcn. I never though of that Da. That would make good sence. And a lot easier. I thought I had it all set, but the cross member was out of level, when I leveled it every thing else moved to. Now I'm back to the beginning again. I'm beginning to think this is a loosing battle. Been on it for two days and not right yet. I hoped to get the motor set up to do the motor mounts. Maybe next weekend.
Old Oct 1, 2007 | 07:04 AM
mechmagcn's Avatar
mechmagcn
Don't get discouraged Rusty. If you think installing the Jag suspension is tough, try installing a frame graft and trying to get that lined up. Step back, maybe try a few of Bobby's frosties (enough of these and you won't care if it runs backwards, at least while under the influence), and then look at it again. Thing will work out in the end.
Old Oct 1, 2007 | 07:50 AM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Did someone say frosties?????
Rusty, I feel for ya, it sounds like the frustration level is geting pretty high. Actually th esuggestions for a few frosties is a good one. Step back and take a few deep breaths and relax a bit. Maybe walk away for a few days or work on something else.
After that I'd pretty much start from square one. Find some decent stationary points on the frame and measure it up, get it where you are happy, then start levelig up the x-member and finally the rear suspension.
this time it will all fall into place (at least thats what I always tell myself)
Good luck
Bobby
Old Oct 1, 2007 | 10:08 AM
RUSTY50F1's Avatar
RUSTY50F1
Well it's Monday morning. I quit working on the truck yesterday about 4 in the afternoon.(To keep from throwing things) I'm going to try again using a stationary point this time. Thanks for the help
mechmagcn,bobbytnm. (The frosties helped. My head is clear this morning) I'm off work today so we'll thy it again.
Old Oct 1, 2007 | 10:18 AM
GreatNorthWoods's Avatar
GreatNorthWoods
I wouldn't worry too much about being off 1/8 of an inch. I doubt if even factory standards were that close front to rear when these trucks were built. It's not worth beating yourself up over. Have another frostie beverage and move on...
